MBDriscoll
SQL Sever Database Error in 10.4 - 10.5; It OK in 10.3.1
Discussion created by MBDriscoll Champion on Feb 7, 2017
Latest reply on Feb 7, 2017 by MBDriscoll
I am having trouble with one of my sql server databases where it will not display in ArcMap and if I do any processes, ie clip, the output is empty. This only happens in 10.4 - 10.5, if I revert back to 10.3.1 the problem goes away. If I open the attributes in ArcMap I can see them all and what I select through the attribute table you can see it highlighted in the data frame.  So it is technically being somewhat read and seen but not really.  Here are some of the errors which come up.
Outcomes
