PrismaGeoCensus
Assignments are not editable/visible
Discussion created by PrismaGeoCensus on Feb 6, 2017
Latest reply on Feb 7, 2017 by cgillgrass-esristaff
Our assignments are not visible in the webapplication since the update of Workforce. On the left, you should see all the assignments and from there, normally you are able to edit and assign them to your workers. Now, the assignments tab is loading continuously and we aren't able to do anything with it (see the screenshot). Our assignments are created by an automatic process using FME. Has something changed in the settings after the update? Anyone having the same problem?
Outcomes
