Open webpage with info from a field in Survey123
1172
02-03-2017 06:57 AM
by Anonymous User
Not applicable
What is the best way to make the user open a webpage from Survey123.
What kind of field works best?
I want the user to open an url containing a field ( ${fieldname})
Tags (1)
JamesTedrick
Esri Esteemed Contributor
In theory, you would want a note type field with a calculation involving the html code.  Currently, there is an issue in calculating html code that prevents this from proceeding successfully.
by Anonymous User
Not applicable
Thanks for a fast respons. Are you working on a solution or should I register it as an idea?
JamesTedrick
We have the dynamic html logged as an issue, but it's not currently being worked on.  Registering it as an idea would be helpful in letting us keep track of general user interest.
by Anonymous User
Not applicable
Here is the registered idea:
https://community.esri.com/ideas/13097
Please vote if you like the idea!
