PFBC_GIS_02
Best Solution for old tool to be used in ArcPro
Discussion created by PFBC_GIS_02 on Feb 2, 2017
Latest reply on Feb 3, 2017 by maxmaxmaxmaxmax
Looking for suggestions on turning this VBA script used as an Add-in to Arcmap into a tool (python?) in ArcPro.
Rivermile tool VBA script
'+++ Each route layer (Polyline with Ms) automatically has a route layer extension
  '+++ attached to it when it is added to ArcMap. This example steps through all the
  '+++ layers in the focus map. For each layer that has a route layer extension, the
  '+++ route location(s) at the user-defined mouse click will be displayed in a
  '+++ message box.
  If Not button = 1 Then Exit Sub      '+++ make sure it is the left button
  Debug.Print "x = " & X & "y = " & Y
  Dim pMxApp As IMxApplication
  Dim pMxDoc As IMxDocument
  Dim pMap As IMap
  Dim pActiveView As IActiveView
  Dim pLayer As ILayer
  Dim pFLayer As IFeatureLayer
  Dim pDS As IDataset
  Dim pLayerExt As ILayerExtensions
  Dim pRtLayerExt As IRouteLayerExtension
  Dim pEnvelope As IEnvelope
  Dim pRtLocator As IRouteLocator2
  Dim pRtLoc As IRouteLocation2
  Dim pRMPointLoc As IRouteMeasurePointLocation
  Dim pRMLineLoc As IRouteMeasureLineLocation
  Dim pFeat As IFeature
  Dim pName As IName
  Dim pEnum As IEnumRouteIdentifyResult
  Dim str As String
  Dim i As Long, j As Long
  Dim pEventLayer As ILayer
  Dim pEventFeatureLayer As IFeatureLayer
  Dim pFeatureCursor As IFeatureCursor
  Dim pFeature As IFeature
  Dim pFeatureClass As IFeatureClass
  Dim pQueryFilter As IQueryFilter
  Dim pQueryString As String
  Dim pFMeas As Double
  Dim pFMeasField As Integer
 Dim pTMeas As Double
  Dim pTMeasField As Integer
  Dim pSegLength As Double
  Dim pFromDist As Double
  Dim pPercSeg As Double
  Dim pRivFromField As Integer
  Dim pRivFrom As Double
  Dim pRivToField As Integer
  Dim pRivTo As Double
  Dim pRivSegDist As Double
  Dim pRivMilepoint As Double
  Dim pRivMiles As Double
  Dim pMiles As String
  Dim pCounter As Integer
  Dim pPoint As IPoint
  'PFBC edits - variables for stream names to come up
  Dim pNameField As String
  Dim pName2 As String
  '+++ Get the focus map
  Set pMxApp = Application
  Set pMxDoc = Application.Document
  Set pMap = pMxDoc.FocusMap
  '+++Capture x,y of location clicked
  Set pPoint = pMxDoc.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(X, Y)
  '+++ Create an envelope out of the map's current location and expand it by the
  '+++ search tolerance
  Set pEnvelope = pMxDoc.CurrentLocation.Envelope
  pEnvelope.Expand pMxDoc.SearchTolerance, pMxDoc.SearchTolerance, False
  '+++ Step through the layers. For each layer that has a route layer extension
  '+++ get the route location(s) where the mouse was clicked.
  For i = 0 To pMap.LayerCount - 1
    Set pLayer = pMap.Layer(i)
    If TypeOf pLayer Is IFeatureLayer Then
      Set pFLayer = pLayer
      Set pDS = pFLayer.FeatureClass
      ' Only have the NHDFline information show up in the string, this removes reference to event table and junctions
      If pDS.BrowseName = "NHDFlowline" Then
        'str = str + pDS.BrowseName + ":" + vbCrLf
        Set pLayerExt = pFLayer
        For j = 0 To pLayerExt.ExtensionCount - 1
          If TypeOf pLayerExt.Extension(j) Is IRouteLayerExtension Then
            Set pRtLayerExt = pLayerExt.Extension(j)
            Set pName = pRtLayerExt.RouteLocatorName(pLayer)
            Set pRtLocator = pName.Open
            Set pEnum = pRtLocator.Identify(pEnvelope, "")
            pEnum.Reset
            If pEnum.Count > 0 Then
              pEnum.Next pRtLoc, pFeat
              While Not pFeat Is Nothing
                If TypeOf pRtLoc Is IRouteMeasurePointLocation Then
                  Set pRMPointLoc = pRtLoc
                  pRID = CStr(pRtLoc.RouteID) 'makes specific reachcode a variable
                  pPtMeasLoc = CStr(Round(pRMPointLoc.Measure, 3)) 'makes it possible to have measure as variable
                  For k = 0 To pMap.LayerCount - 1
                  Debug.Print pMap.Layer(k).Name
                  'Debug.Print "pa_stream_" & Left(pRID, 8) & "gh_l"
                    'If pMap.Layer(k).Name = "pa_stream_" & Left(pRID, 8) & "gh_l" Then 'This is the old code 7/25/05
                     If pMap.Layer(k).Name = "pa_stream_en" Then
                        Set pEventLayer = pMap.Layer(k)
                        Set pEventFeatureLayer = pEventLayer
                        Set pFeatureClass = pEventFeatureLayer.FeatureClass
                        Exit For
                    End If
                  Set pQueryFilter = New QueryFilter
                  pQueryString = "RCH_CODE = '" & pRID & "'"
                  pQueryString = pQueryString & " and F_MEAS <= " & pPtMeasLoc
                  pQueryString = pQueryString & " and T_MEAS >= " & pPtMeasLoc
                  pQueryFilter.WhereClause = pQueryString
                  Set pFeatureCursor = pFeatureClass.Search(pQueryFilter, False)
                  Set pFeature = pFeatureCursor.NextFeature
                  pCounter = 0
                  'PFBC edits - sets value for stream names
                  pNameField = pFeature.Fields.FindField("GNIS_NAME")
                  pName2 = pFeature.Value(pNameField)
                  Do While Not pFeature Is Nothing
                    pFMeasField = pFeature.Fields.FindField("F_MEAS")
                    pFMeas = Round(pFeature.Value(pFMeasField), 3)
                    Debug.Print "The value of pFMeas is " & pFMeas
                    pTMeasField = pFeature.Fields.FindField("T_MEAS")
                    pTMeas = Round(pFeature.Value(pTMeasField), 3)
                    Debug.Print "The value of pTMeas is " & pTMeas
                    pSegLength = pTMeas - pFMeas
                    Debug.Print "The length of the segment is " & pSegLength
                    pFromDist = Round(pPtMeasLoc - pFMeas, 3)
                    Debug.Print "The distance from the node is " & pFromDist
                    pPercSeg = Round((pFromDist / pSegLength) * 100, 3)
                    Debug.Print "The percentage of the segment is " & pPercSeg
                    pRivFromField = pFeature.Fields.FindField("F_RM")
                    pRivFrom = Round(pFeature.Value(pRivFromField), 3)
                    Debug.Print "The value of pRivFrom is " & pRivFrom
                    pRivToField = pFeature.Fields.FindField("T_RM")
                    pRivTo = Round(pFeature.Value(pRivToField), 3)
                    Debug.Print "The value of pRivTo is " & pRivTo
                    pRivSegDist = Round(pRivTo - pRivFrom, 3)
                    Debug.Print "The river segment is " & pRivSegDist & "miles"
                    pRivMilepoint = Round((pRivSegDist / 100) * pPercSeg, 3)
                    Debug.Print "The value of pRivMilePoint is " & pRivMilepoint
                    pRivMiles = Round(pRivFrom + pRivMilepoint, 3)
                    Debug.Print "River Mile Distance is " & pRivMiles
                    pMiles = pRivMiles
                    pCounter = pCounter + 1
                  Loop
                  str = str + "Stream Name: " + CStr(pName2) + vbCrLf
                                str = str + pRtLocator.RouteIDFieldName + ": " + pRID + vbCrLf
                  'PFBC edits - displays stream name on pop up
                  str = str + "River Miles: " + CStr(pMiles) + vbCrLf
                  str = str + "long. = " & pPoint.X & vbCrLf
                  str = str + "lat. = " & pPoint.Y & vbCrLf
                                str = str + vbCrLf
                End If
              Wend
              Exit For
            End If
          End If
        Next j
      End If 'NHDFlowline only
    End If
  Next i
 '+++ Display the found route location(s).
  If pCounter > 0 Then
    MsgBox str, vbInformation, "Identify Route Locations"
  Else
    MsgBox "Segment does not exist in PA dataset.  Try clicking closer to the line." & vbNewLine & vbNewLine & "Also be sure you have the pa_stream_en & NHDFlowline layers loaded in this Map Document." & vbNewLine & vbNewLine & "Pa_stream_en is under K:\PFBC_GIS\Shapefile\Base_Mapping\NHD_Streams_Lakes\" & vbNewLine & vbNewLine & "NHDFlowline is under K:\PFBC_GIS\Geodatabase\NHD_June_05.mdb\Hydrography"
  End If
  Exit Sub
EH:
  MsgBox "An error occurred: " + Err.Description & vbNewLine & vbNewLine & "Is Reachcode set as the Route Identifier for NHDFlowline?" & vbNewLine & vbNewLine & "To check, go the Properties of the NHDFlowline layer --> Routes tab --> choose Reachcode for the Route Identifier" & vbNewLine & vbNewLine & "Now try again - if it doesn't work, call Mike at 717-705-7909!", vbExclamation, "ERROR"
  End Sub
Private Sub rivermiletool_Select()
End Sub
Outcomes
