does Dom support selecting items by class name
1198
5
02-01-2017 01:08 PM
EvonFranklin
New Contributor III
On(Dom.byId("class-name"),
This works for listening for ID changes, however is there a way to target DOM elements by class name?
Tags (1)
EvonFranklin
New Contributor III
On(document, On.selector(".imgs", Mouse.enter), function(){logger();});
Eventually used this, I had to import the "Mouse" and "Query" dojo kits as well.
RobertScheitlin__GISP
Evon,
   You can use "dojo/query"
i.e.
var nl = query(".someClass", "someId");
EvonFranklin
New Contributor III
and this will be enabled for dynamically added elements with the same class name? (.someClass) is added to the DOM tree after a button is pressed. Then can I add a "hover" listener to this element?
Sure
EvonFranklin
New Contributor III
I see, I want to ultimately achieve a mouseover effect when the mouse hovers over a certain img tag.
EvonFranklin
New Contributor III
