AnsweredAssumed Answered
Renaming Enhanced Search Widget
Question asked by william.miller_WarrenCoGIS on Jan 25, 2017
Latest reply on Jan 25, 2017 by william.miller_WarrenCoGIS
I renamed Robert's Enhanced Search Widget after making some changes. I am able to go through the setup in web appbuilder, but when I click OK to complete the widget's configuration, I get the error below and no option to save the changes. The widget is copied to the app, but no config file is saved. I've removed my code and just changed the widget name in all the files (attached), and I've tried restarting WAB multiple times, but the problem persists. Any help is greatly appreciated.
Thank you.
William
TypeError: Cannot read property 'en-us' of undefined  init.js:113
  at Object.<anonymous> (FeatureActionManager.js?wab_dv=2.2:174)
  at Object.forEach (init.js:70)
  at Object.registerWidgetFeatureActions (FeatureActionManager.js?wab_dv=2.2:162)
  at Object.<anonymous> (FeatureActionManager.js?wab_dv=2.2:207)
  at init.js:63
  at visitBigSection (utils.js?wab_dv=2.2:120)
  at Object.visitElement (utils.js?wab_dv=2.2:85)
  at Object.c.visitElement (ConfigManager.js?wab_dv=2.2:177)
  at Object._reRegisterWidgetActions (FeatureActionManager.js?wab_dv=2.2:204)
  at Object._onAppConfigChanged (FeatureActionManager.js?wab_dv=2.2:252) "TypeError: Cannot read property 'en-us' of undefined
  at Object.<anonymous> (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:174:82)
  at Object.forEach (http://js.arcgis.com/3.18/init.js:70:348)
  at Object.registerWidgetFeatureActions (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:162:15)
  at Object.<anonymous> (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:207:28)
  at http://js.arcgis.com/3.18/init.js:63:209
  at visitBigSection (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/shared/utils.js?wab_dv=2.2:120:13)
  at Object.visitElement (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/shared/utils.js?wab_dv=2.2:85:5)
  at Object.c.visitElement (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/ConfigManager.js?wab_dv=2.2:177:19)
  at Object._reRegisterWidgetActions (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:204:19)
  at Object._onAppConfigChanged (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/FeatureActionManager.js?wab_dv=2.2:252:14)
  rejected at a (http://js.arcgis.com/3.18/init.js:108:174)
  at h (http://js.arcgis.com/3.18/init.js:107:438)
  at g.then.c.then (http://js.arcgis.com/3.18/init.js:110:152)
  at Object._onWidgetPoolChanged (http://pcName.domainName:port/webappbuilder/apps/6/jimu.js/ConfigManager.js?wab_dv=2.2:285:72)
  at f.<anonymous> (http://js.arcgis.com/3.18/init.js:63:209)
  at f.c [as onbuilder/widgetPoolChanged] (http://js.arcgis.com/3.18/init.js:119:79)
  at Function.h.emit (http://js.arcgis.com/3.18/init.js:124:331)
  at Function.h.emit (http://js.arcgis.com/3.18/init.js:125:443)
  at f.emit (http://js.arcgis.com/3.18/init.js:117:218)
  at Object.publish (http://js.arcgis.com/3.18/init.js:169:289)
Error
  at g.then.c.then (http://js.arcgis.com/3.18/init.js:110:97)
  at Object.<anonymous> (http://pcName.domainName:port/webappbuilder/builder/main.js?wab_dv=2.2:2111:232)
  at f.<anonymous> (http://js.arcgis.com/3.18/init.js:63:209)"
Outcomes
