I've created a simple web site that asks a user to log in to ArcGIS Online, using the following code:
<!DOCTYPE html>
<html>
<head>
<title></title>
<meta charset="utf-8" />
<link rel="stylesheet" href="https://js.arcgis.com/3.19/esri/css/esri.css" />
<script src="https://js.arcgis.com/3.19/"></script>
<script>
require([
"esri/arcgis/OAuthInfo",
"esri/IdentityManager"
], function (OAuthInfo, esriId) {
var info = new OAuthInfo({
appId: "ycS0y2RsQMqf22mG",
popup: false
esriId.registerOAuthInfos([info]);
esriId.checkSignInStatus(info.portalUrl + "/sharing").then(
function () {
).otherwise(
function () {
esriId.getCredential(info.portalUrl + "/sharing");
</script>
</head>
<body>
</body>
</html>
After IdentityManager.getCredential() is called on line 24, the Visual Studio debugger exits with errors:
The program '[2224] iexplore.exe' has exited with code 0 (0x0). The program '[10128] iisexpress.exe' has exited with code 0 (0x0).
The application is still running in Internet Explorer, however.
Has anyone else experienced this, and is there a way to work around it?
