AnsweredAssumed Answered
Difference in Feature Services between Survey123 Connect and Survey123 Web
Question asked by Blian2 on Jan 9, 2017
Latest reply on Jan 9, 2017 by JTedrick-esristaff
When publishing a survey from Survey123 for Web, it generates a form and two different feature services.
But, when publishing a survey from Survey123 Connect it only creates a form and one feature service.
Both methods work fine in terms of collecting data on the Survey123 mobile application.
I am using the python script created by jtedrick to pull data from hosted feature services into our Enterprise Geodatabase. It works fine against the Survey123 for Web feature layer, but against the Survey123 Connect created feature layer it just migrates empty tables. I have the settings for the two feature services the same, the only thing that is different seems to be the second feature service(the one that says "hosted,view") that is generated when using Survey123 for Web. Am I missing a step when publishing feature services from Survey123 Connect?
Outcomes
