What is the difference between these user addition options?
1605
01-10-2017 12:14 PM
AllWeatherHeather
We started with ArcGIS Online and now we're configuring Portal for ArcGIS 10.4.1. As we figure out the security options and what will work best for us I have a question about the difference between the way they each work.
In ArcGIS Online...
In Portal 10.4.1...
Both are configured to use ADFS for authentication. What is the difference between these three user addition options?
Heather
DerekLaw
Esri Esteemed Contributor
Hi Heather,
The first two options:
  • ArcGIS Online - Invite members to join using their enterprise logins
  • Portal for ArcGIS - Add members for JD Irving enterprise logins via SAML
are conceptually similar, in that both use SAML authentication. In other words, your are leveraging a 3rd party identity provider to authenticate your logins. Some resources,
The third option for Portal only,
  • Portal for ArcGIS - Add members based on existing enterprise users
is for adding users if you've enabled integrated Windows Authentication (IWA) on your Portal. More resources,
In your case, since you're using ADFS and you are configuring Portal for ArcGIS 10.4.1, you would select the second option.
Hope this helps,
DerekLaw
Hi Heather,
Hope this helps,
