AnsweredAssumed Answered
Cannot pick 'procedural layer' for point shapes in Arcgis Pro, cannot apply CityEngine rule pack
Question asked by esrilmo on Jan 6, 2017
Latest reply on Aug 2, 2017 by jshell
Hello, I created a rule package which uses CityEninge's tree library. I added the additional annotations so it would work in ArcGIS pro. (little cga code below). I want to generate the trees in ArcGis Pro using the 'procedural layer' option, which I should be able to select from the symbology > Properties drop down, right?  but this option does not appear. I only get marker, stroke and fill layer options. How I can assign the rule package to point shapes?.  The point data I have is a the city's vegetation in shape file. Using arcgis pro 1.3
I tried converting converting the points to multipatch but then, the rpk does not apply since it is annotated with @InPoint. So, I would need an annotation for @Multipatch????? Using the preset option forces using a single color.
the code below is a minimized version. In reality it calls other 2 little cga files, but for testing I took may sections out.
I guessed the order of how the additional annotations should go, so I am not entirely sure.. pls advise if this is wrongly done, too.
import Tree_Options: "rules/Esri Vegetation Library with LumentRT 3D Plants - Plant Loader.cga"
#import Root_Options:"rules/aoi_roots.cga"
#import LOD1_trees:"rules/aoi_lod1_tree.cga"
#   Inspector - Trees  ##############################
@Order(1) @Range("Cylinder","Lollypop","Fan","Analytical","Model")
attr Representation        = "Analytical"
@Group("Trees",1)
    @Order(1)
    attr Genus        = "Robinia"
    @Hidden
    attr Species    = "Pseudoacacia"
    @Order(2)
    @Distance
    @Range(0,30)
    @Description("Change diam 0-30m")
    attr Canopy_Diameter     = 8
    @Hidden
    @Distance
    @Range(0,160)
    attr Radius = Canopy_Diameter/2
    @Order(3)
    @Distance
    @Range(0,160)
    @Description("Change 0-160m. Red trees have H<0")
    attr Height     = 10
    @Order(4)
    @Range(0,1)
    @Description("between 0 to 1")
    attr Transparency         = 0
################## START
@StartRule @InPoint
load --> loadTrees
loadTrees -->
    set(Tree_Options.Name, Tree_Options.getCommonName(Genus,Species))
    set(Tree_Options.Radius,case Canopy_Diameter >0: Canopy_Diameter/2 else: Tree_Options.getRadius)
    /* set(Tree_Options.Height,case Height<0: 10 else: Height) drawRedCylinder
    Tree_Options.Generate */
    set(Tree_Options.Height,case Height<0: 10 else: Height) Tree_Options.Generate
Outcomes
