AnsweredAssumed Answered
Popup - show field only when editing
Question asked by Martin-Munin on Jan 6, 2017
Latest reply on Jan 13, 2017 by GChristakos-esristaff
Hi.
When setting up popups in AGOL map to use with Collector for ArcGIS, we used to setup some fields to show only when editing a feature. However, currently when a check mark is set only for EDIT and not for DISPLAY, no fields are displayed in Collector when editing the feature. Is this a bug, or is this intentional.
We are using iOS for Collector. We are aware that when using Android, the field had to be set up both for display and edit to show under editing.
When field is only setup for editing, it will not show up when editing the featuer (iOS)
I would like to add that we have found the possibility to show only fields when editing very useful. Hopefully it is coming back.
Martin
Outcomes
