locators not showing in10.5, but show in 10.4 and 10.3
1483
5
01-03-2017 07:48 AM
JasonLyon
New Contributor III
Upgraded desktop to 10.5 last week, but found today that 2 locators within a geodatabase do not show in 10.5, but when viewed on a 10.3 and 10.4 they show. I did not have the same issue when upgrading from 10.2 to 10.3 and 10.4.
Solution to this issue other than rebuilding locator?
Asrujit_SenGupta
MVP Regular Contributor
Try copying that Locator to a folder connection (not inside any geodatabase) and then check using 10.5
MichaelVolz
Esteemed Contributor
Address locators stored in geodatabases are no longer supported as per:
Geocoding Improvements and Deprecations in ArcGIS Desktop 10.5 and ArcGIS Pro 1.4 | ArcGIS Blog
JasonLyon
New Contributor III
Thanks did not catch this even in the 10.4 to 10.4.1 depreciation
Ahmed_AltafTambe
New Contributor III
As mentioned in the below web-link:
" Locators should be stored in a file folder so you take advantage of new features that are not supported for locators stored in geodatabases, such as performance improvements, multithreading capabilities, and suggestions support. ArcGIS 10.4 is the last release to support storing locators in geodatabases.  "
Here is the web-link for reference:
Creating an address locator—Help | ArcGIS Desktop
JasonLyon
New Contributor III
My issue is working with a third party on CAD/Dispatch backend, so trying to find a solution as they move forward as well.
Thanks for the help everyone on the answers
