AnsweredAssumed Answered
Show the attribute inspector without saving a new feature
Question asked by ozcandurak on Dec 29, 2016
Latest reply on Jan 3, 2017 by rscheitlin
The requirement is to add a new feature from template picker but without applying it, can i show the attribute inspector than save the feature.
selectedTemplate = templatePicker.getSelected();
This selectedTemplate is then selected to put the points on the map than opens the attribute inspector by selecting it.
selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
Sample Code Block :
  1.  dojo.connect(drawToolbar, "onDrawEnd", function(geometry) {
  2.           //display the editable info window for newly created features
  3.
  4.           if (map.infoWindow.isShowing) {
  5.             map.infoWindow.hide();
  6.           }
  7.
  8.           drawToolbar.deactivate();
  9.
  10.           var fieldAttributes = layerFieldToAttributes(selectedTemplate.featureLayer.fields);
  11.           var newAttributes = dojo.mixin(fieldAttributes, selectedTemplate.template.prototype.attributes);
  12.           var newGraphic = new esri.Graphic(geometry, null, newAttributes);
  13.
  14.           var layerInfos = [{
  15.             'featureLayer': selectedTemplate.featureLayer,
  16.             'isEditable': true
  17.           }];
  18.
  19.           var attInspector = new esri.dijit.AttributeInspector({
  20.             layerInfos: layerInfos
  21.           }, dojo.create("div"));
  22.
  23.           selectedTemplate.featureLayer.applyEdits([newGraphic], null, null, function() {
  24.             var screenPoint = map.toScreen(getInfoWindowPositionPoint(newGraphic));
  25.
  26.             map.infoWindow.setContent(attInspector.domNode);
  27.             map.infoWindow.resize(325, 185);
  28.             map.infoWindow.show(screenPoint, map.getInfoWindowAnchor(screenPoint));
  29.
  30.             templatePicker.clearSelection();
  31.           });
  32.
  33.           dojo.connect(attInspector, "onAttributeChange", function(feature, fieldName, newFieldValue) {
  34.             feature.attributes[fieldName] = newFieldValue;
  35.             feature.getLayer().applyEdits(null, [feature], null);
  36.           });
  37.
  38.           dojo.connect(attInspector, "onDelete", function(feature) {
  39.             feature.getLayer().applyEdits(null, null, [feature]);
  40.             map.infoWindow.hide();
  41.           });
  42.         });
  43.       }
I would like my client first add the attribute to feature and (save & apply) it.
Any help would be appreciated.
Outcomes
