Why are severe errors showing up when doing a rematch using a geocoding service?
341
12-15-2016 09:00 AM
soniadickerson1
When using our composite geocode service in ArcMap, the log files fill up with the following errors when the user runs the rematch.
Method failed.HRESULT = 0x80004005 : Unspecified error .
Request with this name is not supported
I set the logs to record debug information and this entry occurs before the Method failed error:
.\CompositeLocator.cpp(4678): CHECK_HR((_ParallelCompositeLocatorMatch( getMappingsMethod, matchMethod, backupPlan, pInput, ppResult))) failed in long __cdecl CompositeLocator::_CompositeLocatorMatch(void (__cdecl WL::* )(class Mappings *&,class Mappings *&),long (__cdecl IAddressCandidates::* )(struct IPropertySet *,struct IArray **),struct IPropertySet *,struct IArray **,int,long (__cdecl *)(struct ILocator *,struct IPropertySet *,struct IArray **))
Has any one had the same type of issue and come up with a resolution?
Thanks very much.
Sonia
