pass data to Survey123 note or hidden field not working
7238
16
12-14-2016 10:54 AM
danbecker
Occasional Contributor III
ArcGIS online popup config, custom attribute display.
I included a link to survey123 in the correct format, but I cannot pass data from the clicked feature to any survey123 fields that are type: "note" or "hidden".
&field:hidden_name={featureService_fieldName}
I checked the schema field type of the hidden and note field and its string, this matches the feature service attribute type.
passing data to a survey123 type: "text" field works fine, but it has to be editable, i.e. read_only = "".
I'm just trying to link clicked features to forms, WITHOUT the field being editable in survey123. If you pass a string to a type: "text" field in survey123 it works, but what happens when the user edits that field...you no longer have joinable data.
This is why I wanted to pass a value to a hidden or non-editable field but I just cant....
any ideas?
JosephAlberts
New Contributor III
dbecker88‌ Have you had any success working around this? I stumbled onto the same issue; it seems like a reasonable work-around until Survey123 is capable of updating existing feature class records. At least you can connect your survey back to your data after the fact.
BrentKinal1
I just came across the same issue, I would like to pass two values from Collector to my Survey123 form and lock them from editing in Survey123. Tried making them hidden, notes and read only, unfortunately none of these populate with the values coming from Collector. As far as I can tell there is no way to lock the values. If someone comes up with a solution please share.
LeonS
I am also looking for the same capability.  It makes sense to want to pass the unique feature ID from Collector to Survey123 and have the ID value not editable within the survey.
danbecker
I did not make any headway in getting a read-only value to populate in survey123.
I just told all the field staff to NOT TOUCH the ID field that was pre-populated from Collector.
The ideal scenario would be to use survey123 hidden field, then field staff won't even ask a question.
LeonS
Thanks, Dan.  I just posted an idea related to this....
https://community.esri.com/ideas/13341
MikeOnzay
I was able to pass a value to a note field (but not a hidden field) in survey123 today. The trick is to use the calculate field as JTedrick suggested in his reply to this post on March 3rd. https://goo.gl/BRQqOD. I used the function today() in three cells and the value of 1 in another cell. This is working on my desktop browser. On an IPad with Explorer it sort of works. The first two note values and the last note value pass correctly but the third and fourth one are not passing correctly in the iPad.
XML for passing note values
passed values into form
MikeOnzay
I now have it working on the iPad. I found that the two values that were not passing correctly were due to capitalization in the custom URL. I guess Survey123 on the iPad is pickier than on the desktop.
&field:containers_size={Containers_Size} - passed value correctly in desktop but not iPad
&field:containers_size={CONTAINERS_Size} - passed value correctly in desktop AND iPad
LeonS
Thanks, that trick worked!
Leon
IsmaelChivite
Esri Notable Contributor
Hi. This is to let you know that in version 2.1 (scheduled to be released this week)  we have  addressed this issue. You will be able to pass values to hidden and notes using the custom url scheme, and without  tricks...
