Point Density Error
3330
10
12-13-2016 11:36 AM
SangThao
I'm trying to run a point density analysis and keep getting the following errors. Attached below. I'm using model builder to run the point density analysis.
DanPatterson_Retired
before you try anything else, move the source file to a file without spaces and other stuff... same for the destination
A F is a usb of other type of non-real drive... move it to a desktop folder
AdamZiegler1
Is there enough disk space on the destination drive?
-Adam Z
SangThao
Thank you, I moved it into it's own file database. Everytime I do run I get something different from tutorials I've been looking at.  This is how my density map looks like. What's wrong when I run the model? Is my data bad?
 Density map.
 My data.
go to the layer's properties, select symbology and choose a different colour ramp... try for a lighter one than B to W
Point Density—Help | ArcGIS Desktop
SangThao
It's still not overlaying.
 I want it to look like this. I got this from a video, I'm going through the steps as he is but somehow my maps come up in one big block and it's not overlayed and looks like the one above
well you haven't indicated the options you used... which are probably the defaults... which you should think about.  And I just want to check that you want point density and not kernel density Kernel Density—Help | ArcGIS Desktop they are slightly different in their expression although it is magnitude per unit area as a base
SangThao
Thanks Dan. I appreciate the help.  The tutorials I did look at used point density and produced those maps.
These are the options I'm using. I want to create a map where the more points there are the more density it shows.  My map is currently in meters.
Ok... the warning .... quit using folders and filenames with spaces in them... just don't, even if they work sometime, they will bite you... old school will leap in I hope to support this notion.
now.  your cell size and radius... why chosen?  why a circle?  what does it say in the help? what happens when you vary these parameters?  Don't try to emulate an example unless you know that your data and conditions enable you to reproduce the same outcomes.  You got what you got because that is what you used.  If you check the parameters there is lots you have to understand, since each parameter variation will produce a different output.
Since this seems to be an assignment or a final project, it is your turn to justify what you chose and why.. Just because it is a default... if that is the case ... certainly doesn't make it right or even good.
Good luck
SangThao
I did use the kernel density tool too, it looks like that IS the map I wanted to create. Thanks.
