Get SSL details thorugh portalpy
2396
11
12-14-2016 08:16 AM
ADITYAKUMAR1
Occasional Contributor III
Hi team,
  I am working on portal.py. I am trying to get the details of SSL certficates which the portal is using.
 I have tried with some code but nothing is working. Any suggestion on this will be helpful.
import sys
sys.path.append('..')
import portalpy
import csv
import ssl, socket
portalUrl           = "https://xxx-xxx.xx.xx.com:7443/arcgis"
portalAdminUser     = "xxxx"
portalAdminPassword = "xxxx"
portal = portalpy.Portal(portalUrl, portalAdminUser,portalAdminPassword)
users = portal.search_users('(role:account_admin OR role:account_publisher  OR role:account_user)')
activeUser = portal.logged_in_user()
print activeUser['email']
ctx = ssl.create_default_context()
s = ctx.wrap_socket(socket.socket(),server_hostname='http://xxx-xxx.xxxx.com/arcgis/home/')
s.connect((portal, 443))
cert = s.getpeercert()
print cert
Aditya Kumar
RebeccaStrauch__GISP
Joshua,
I was able to run this in the Pro python window, but had to add ( ) around the print string.  Based on things I've read on one of Dan's /blogs/dan_patterson/2016/05/09/the-links?sr=search&searchId=a1012d53-da1f-4df7-b109-573165a00e62&se...‌ blogs, that is a requirement for the 3.x python flavors.
So, yours is the correct answer, but here it is with the change
import ssl, socket
hostname = 'geonet.esri.com'
s = ctx.wrap_socket(socket.socket(), server_hostname=hostname)
s.connect((hostname, 443))
props = []
props.append(('Valid from', cert['notBefore']))
props.append(('Valid to', cert['notAfter']))
props.append(('Serial number', cert['serialNumber']))
for name,value in props:
     print ("{:<20}{}".format(name, value))
I was able to successfully run this against my own hostname.  thanks.
I edited your post and formatted the python code to help others to debug.
For future reference, so format your code, in the toolbar for the post/comment,
  • click on the   ...
  • Select MORE
  • Select Syntax Highlighter
  • Select your programming language
  • post your code.
JoshuaBixby
MVP Esteemed Contributor
Does the following from StackOverflow work:  How can i get Certificate issuer information in python?
import ssl, socket
hostname = 'xxx-xxx.xxxx.com'
subject = dict(x[0] for x in cert['subject'])
issued_to = subject['commonName']
issuer = dict(x[0] for x in cert['issuer'])
issued_by = issuer['commonName']
ADITYAKUMAR1
It failed to connect. Tried the same.
I tried that and got an error from line 4
import ssl, socket
hostname = 'mySite'
  Python Shell, prompt 6, line 4
AttributeError: 'module' object has no attribute 'create_default_context'
RandyBurton
I used  hostname = 'google.com' in line 3 of bixb0012‌'s code, added a couple of print statements and had no issues obtaining google's info.
I would suggest just using your base domain "xx.com" (from your sample code - with no "https://xxx.x....") for the host in line 3 of Joshua's code.  You may need to use port 7443 instead of 443 in line 6.
ADITYAKUMAR1
Thanks a lot Randy Butron and Joshua. It really helped and its working.
For my machine, it must be another issue.  For me, even after importing the ssl, it doesn't find
and never gets to the next line.  Using Wing Pro 5.1.12-1 python shell and ArcCatalog python window. Somehow I must be getting an incorrect version of ssl ??  the ssl comes up in the intellisense (i.e. other ssl attributes work), but not the create_default_context.  Not critical for my work right now so I won't spend a lot of time figuring it out on my system, but it does sound like a nice tool.
RandyBurton
From github, ssl.create_default_context was added in 2.7.9.  I also received the same error as you when using Python 2.7.5.
ADITYAKUMAR1
I was able to get al the details. But I am not able to segregate the details. Like expiry date,issued date,serial number.
Any idea?
