Hi
I am using floating pane to display datagrid, however it doesnot show me close button on title pane:
Here is the sample code:
var detailsGrid = dijit.byId("ShowVBBDetailsGrid");
if (detailsGrid) {
detailsGrid.destroy();
var FP = dijit.byId("FloatingPaneFrVbbDetails");
if (FP) {
// FP.destroyRecursive(false);
else {
_this.FloatingPaneFrVbbDetails = new FloatingPane({
title: _this.nls.ExpiredVBB,
resizable: false, dockable: false,
// displayCloseAction: true,
closable: true,
style: "width:752px;height:124px;display:block;left:250px;top:100px;position:absolute;z-index:400;overflow:hidden",
}, dojo.byId("pFloatingPane"));
_this.FloatingPaneFrVbbDetails.startup();
_this.FloatingPaneFrVbbDetails.show();
var ShowVBBDetailsGrid = new DataGrid({
store: detaildExpriedVbbObjectStore,
structure: myStructure,
selectionMode: "single",
// autoheight:true,
style: "width:736px;height:122px;left:0px;display:block;z-index:500;font-family:Verdana,Arial,sans-serif;font-size:90%"
dojo.place(ShowVBBDetailsGrid.domNode, _this.FloatingPaneFrVbbDetails.containerNode, 'first');
ShowVBBDetailsGrid.startup();
_this.FloatingPaneFrVbbDetails.resize();
Solved! Go to Solution.
Deepika,
If you look at the documentation for the class then you will see this:
You will need to import the FloatingPane.css and ResizeHandle.css files from the dojox/layout/resources directory. The styles are not included in the main Dojo/theme stylesheets because of the experimental status of the widget.
Deepika,
Are you importing the FloatingPane.css and ResizeHandle.css in your code?
no I am not as of now
Deepika,
