Another "Packaging succeeded, but publishing failed"
1620
5
12-11-2016 02:29 PM
BenediktSteiner
Hi All,
as others previously I ran into the following problems trying to share a gdb online. Please see the specific error screenshots below... How can I fix this?
Thank you!
NeilAyres
Well I think this bit says it all
Either use "overwrite service", or provide a different service name.
RebeccaStrauch__GISP
I converted your post to a question (was a discussion). You will get more views that way.
AdrianWelsh
MVP Honored Contributor
Hi Benedikt,
Can you share the results of your GP window (as indicated in your error message)? Your second screenshot is only the publishing warnings you get before publishing. Your GP Results Window will be found under the Geoprocessing menu and then Results
BenediktSteiner
Hi, many thanks. I took a screenshot of the window. Is it possible that something is wrong with my server connection? I am logged in to my organisation though.
BenediktSteiner
Hi All, I wonder if anyone can put me into the right direction how I can solve the problem above? Thank you.
NeilAyres
