AnsweredAssumed Answered
"Unable to load /proxy/?http://localhost Statu 404
Question asked by jsn on Dec 7, 2016
Latest reply on Dec 12, 2016 by rscheitlin
Hello everyone,
I am getting the following error message
"Unable to load /proxy/?http://localhost/FindNextVALUENumber/api/value status: 404"
when running this sample:
https://developers.arcgis.com/javascript/3/jssamples/data_requestJson.html
When I pass these URLs, the first one works fine but the second one fails
url = "http://localhost:59297/api/value";   <ç========WORKS FINE – it is the Visual Studio 2012 proejct
Or
url = "http://localhost/FindNextVALUENumber/api/value"; <ç==== FAILS – runs from IIS
The second URL is the IIS Application pointing to the same folder.
I am using the proxy server from this sample: https://github.com/Esri/resource-proxy
I tested both url and they work fine with the proxy:
http://localhost/proxy/proxy.ashx?http://localhost:59297/api/value
 http://localhost/proxy/proxy.ashx? http://localhost/FindNextVALUENumber/api/value
Here is the proxy.config file
 <ProxyConfig allowedReferers="*"   mustMatch="true">
   <serverUrls>
     <serverUrl url="http://localhost:61004"
                 matchAll="true"/>
     <serverUrl url="http://localhost:59297"
               matchAll="true"/>
     <serverUrl url="http://localhost"
                   matchAll="true"/>
   </serverUrls>
</ProxyConfig>
My code:
            esriConfig.defaults.io.proxyUrl = "/proxy/";
           var url = "http://localhost:59297/api/value";
           dom.byId("url").value = url;
           dom.byId("content").value = "";
           //handle the Go button's click event
           on(dom.byId("submitRequest"), "click", getContent);
           var serviceDescriptionStr = "";
           function getContent() {
               var result = "";
               var contentDiv = dom.byId("content");
               contentDiv.value = "";
               domClass.remove(contentDiv, "failure");
               dom.byId("status").innerHTML = "Downloading...";
               var requestHandle = esriRequest({
                    "url": url,
                   handleAs: "json"
               requestHandle.then(
                                 function (response) {
                                     console.log("Data: ", response);
                                     dojoJson.toJsonIndentStr = " ";
                                     console.log("Success: ", response);
                                 function (error) {
                                      console.log("Error: ", error.message);
                                     alert(error.message);
Outcomes
