AnsweredAssumed Answered
Could you help me on TPK using ArcMap?
Question asked by kym19810726 on Dec 6, 2016
Hello, everyone.
I have been working on ArcGIS.
When I build a map using ArcMap, I have fell onto one issue like this.
This is relevant with a symbology and a representation.
Let you think you have one contour data set.
in this case I want to build map that is represent the contour depend it's altitude and  map scale.
    the altitude           R    G     B     width     transparency
 altitude%50=0      102  162  89       2                 0
altitude%50<>0     102  162  89       1                50%
and when the map scale <1:1000000,     display these contours with only altitude%50=0
and  when the map scale >1:1000000,    display all contours.
I already have worked using the representation on ArcMap.
But My final term is focused on that will use this map on Android as in tpk format.
When I accept to share this map onto in format tpk file, it ignores the representation layer.
Do you have a solution or experience on that?
If you could reply to my question, I should really appreciate for you.
Thank you.
Outcomes
