AnsweredAssumed Answered
Unable to Enable Enterprise Geodatabase (10.4.1)
Question asked by mruiz on Dec 6, 2016
Latest reply on Dec 7, 2016 by mruiz
Hi all, I am having an issue trying to enable the geodatabase (10.4.1):
  1. Oracle 11gR2 64 bits is installed
  2. I could connect from ArcCatalog to the database
But when I try to use the enable tool the message shown is:
Executing: EnableEnterpriseGeodatabase "Database Connections\Connection to gistorde.sde" Z:\keycodes
Start Time: Fri Nov 25 10:51:11 2016
Validated authorization file.
User has required privileges for geodatabase setup.
XML support is enabled for the database instance.
[Underlying DBMS error]
See the setup log in the following location for additional error information:
C:\Users\yterum\AppData\Local\Temp\sde_setup.log
Could not create  geodatabase tables and stored procedures.
Failed to execute (EnableEnterpriseGeodatabase).
Failed at Fri Nov 25 10:51:13 2016 (Elapsed Time: 1,40 seconds)
And the sde_setup.log says:
[Fri Nov 25 10:51:12 2016]
ST_Geometry is not installed.[Fri Nov 25 10:51:12 2016] Instance initialized for ((sde)) . . .
[Fri Nov 25 10:51:12 2016] Error creating VERSION table. (-51)
DBMS error code: 1950
ORA-01950: no existen privilegios en tablespace 'SDE'
[Fri Nov 25 10:51:12 2016] SDE schema object install not completed.
[Fri Nov 25 10:51:12 2016] ERROR installing/upgrading ArcSDE, Error = -51
Can anyone help me?
Thanks in advance,
Mónica.
Outcomes
