remove the adress bar in the related table chart
605
11-30-2016 03:01 PM
JuliaGalindo
Those anyone knows how to remove the address bar form the related table chart widget in the developer web application builder?
Thanks a lot!
RobertScheitlin__GISP
Julia,
   All you need to do is add these two new rules to your apps theme common.css:
(i.e: [install dir]\server\apps\[app#]\themes\FoldableTheme\common.css)
.jimu-widget-RelatedTableCharts .esriCTSearchOuterContainer{
  display: none;
.jimu-widget-RelatedTableCharts .esriCTResultsPanel{
  height: 100%;
Julia,
  display: none;
  height: 100%;
JuliaGalindo
Robert,
Thank you so much! Iit worked perfectly!
Regards,
