how can i group multiple zip codes into different colored sales groups
1833
11-29-2016 04:01 PM
JoshReed
i want to map sales groups which are determined by zip codes, generally different counties but not always.
es- Baldwin Co, AL is divided into 6 different groups with 2-5 zip codes each. i want to map this visually, with each as a different color to make sure that they are mapped correctly and all are included.
KellyGerrow
Esri Frequent Contributor
Hi Josh,
Is there any logic to how you want to group the zip-codes? If there is a common attribute or location in the data set, you can try to symbolize based on that field or consider adding a symbolization field in your dataset and manually define the zip codes that you want to group together by giving them a common value in your dataset.
-Kelly
KellyGerrow
Hi Josh,
-Kelly
