Examples of V100.0: Missing Mil2525DMessages.xml
1015
11-25-2016 05:42 AM
NorbertThoden
Occasional Contributor III
I would like to execute the example GraphicsOverlayDictionaryRenderer_3D.
The executions seems to be stopped and only the backgroundGrid is visible.
A error message says, that the "Mil2525DMessages.xml" is missing 😞
The SampleViewer on windows will download it is the example is started, but i can`t find the location 😞
Can someone support me and attach the file???
BTW: Is it possible that esir will check their examples?
I tried 4 example now, that is the second failure....
(missing include statement)
Thanks in advance!!
Norbert
Tags (1)
LukeSmallwood
Hi Norbert, you should be able to download the missing .xml file from: https://arcgisruntime.maps.arcgis.com/home/item.html?id=3db12175479147ea9c89ebaaf3b89996
Are you running the sample directly from QtCreator or via one of our samples viewers? The sample viewer should take care of downloading any data dependencies for each sample as they are loaded - please let me know if that is not working for you.
For C++ the, the sample viewer apps can be downloaded from http://www.arcgis.com/home/search.html?q=C++%2C%20QtSampleViewer%2C%20100.0.0=&content=all
If you could also let me know which sample has a missing include statement, I can look into that as well.
Thanks for reporting this,
Luke
MaximilianGlas
Hi Luke,
The missing .xml you have mentioned to be on a new location is now missing again
Seems it has been moved or deleted.
Kind regards,
Max
