Dynamically update custom text element for print template layout
3072
12
11-25-2016 01:59 PM
NhuMai
I'm working on setting custom text elements via the template layout options for a print task to be used in a print widget. I am trying to get the custom text to display the lat long coordinates of the current map extent.
I followed this sample to get the widget up and going. However, it sets up the template layouts and starts up the print widget when the app is loaded. This means that my "current" map extent for the layout is the initial map extent. Any suggestions on how to get the template custom text element to update to the current map extent? For the moment, I'm thinking that I have to set up and start up the print widget every time the extent changes...
Here is what I have so far:
require([
 "esri/layers/FeatureLayer",
 "esri/dijit/Print",
 "esri/tasks/PrintTemplate",
 "esri/request",
 "esri/config",
 "dojo/_base/array",
 "dojo/dom",
], function(
 FeatureLayer,
 Print, PrintTemplate,
 esriRequest, esriConfig,
 arrayUtils, dom
//var printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";
 var printUrl = "http://ourserver/arcgis/rest/services/Our_Tools/Our_Print_Tool/GPServer/Exporter%20une%20carte%20Web";
esriConfig.defaults.io.proxyUrl = "http://ourserver/Java/proxy.jsp";
dojo.connect(window.myMap, "onExtentChange", showExtent);
// get print templates from the export web map task
 var printInfo = esriRequest({
 "url": printUrl,
 "content": {
 "f": "json"
 printInfo.then(handlePrintInfo, handleError);
 var center = "";
 var latLong = "";
function handlePrintInfo(resp) {
 var layoutTemplate, templateNames, mapOnlyIndex, templates;
 showExtent(window.myMap.extent)
 layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
  return param.name === "Layout_Template";
if ( layoutTemplate.length === 0 ) {
 console.log("print service parameters name for templates must be \"Layout_Template\"");
 return;
 templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
 mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
 if ( mapOnlyIndex > -1 ) {
 var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
 templateNames.push(mapOnly);
// create a print template for each choice
 templates = arrayUtils.map(templateNames, function(ch) {
 var plate = new PrintTemplate();
 plate.layout = plate.label = ch;
 plate.format = "PDF";
 plate.layoutOptions = {
 customTextElements : [
 centerLatLong: latLong,
 centerXY: center
 return plate;
// create the print dijit
 printer = new Print({
 "map": window.myMap,
 "templates": templates,
 url: printUrl
 }, dom.byId("print_button"));
 printer.startup();
function showExtent(extent) {
 var lat = window.myMap.extent.getCenter().getLatitude().toFixed(2);
 var long = window.myMap.extent.getCenter().getLongitude().toFixed(2);
 latLong = "Latitude : " + lat + " - Longitude : " + long;
 var X = window.myMap.extent.getCenter().x.toFixed(2);
 var Y = window.myMap.extent.getCenter().y.toFixed(2);
center = "X : " + X + " - Y : " + Y;
 console.log(latlong);
 console.log(center);
function handleError(err) {
 console.log("Something broke: ", err);
RobertScheitlin__GISP
Nhu,
   I would not setup or display the print widget until the user clicks a button in the app that says something like prepare to print or something.
Quynh_NhuMai
New Contributor III
Robert,
I considered this option, but there is the possibility that users will pan or zoom right before making their template selection. The print widget template selection is only accessible after the printer is created (or so i believe...).
To make sure the extent printed to the map is correct, I think I would have to prevent users from zooming or panning, which isn't preferable. Do you see any way around this?
I would re-build the print widget on each extent change then if the print has already been opened.
FC_Basson
MVP Regular Contributor
You could handle your print template "plate" as a global variable and on the map extent change event (Map | API Reference | ArcGIS API for JavaScript 3.18 ) set the properties for the dynamic text
map.on('extent-change', function(){
  plate.layoutOptions.customTextElements.centerLatLong = latLong;
  plate.layoutOptions.customTextElements.centerXY = center;‍‍
Quynh_NhuMai
New Contributor III
This is interesting, but the plate variable is used when creating the printer. With your solution, how could I get the print widget this take into consideration the updates to the plate variable? The way I have it set up now, I think that even updating the plate variable with every extent change, the printer would have the values that plate had when the widget was declared.
FC_Basson
You're right - you just need to define the "plate" variable outside of the current function scope, so jou could define it at the start of the main require function (var plate;) and remove the variable declaration within the handlePrintInfo function.
Quynh_NhuMai
New Contributor III
I see what you mean about making "var plate" global. It is true that when doing so, "plate" is correctly updated with each extent change. However, it doesn't update "printer" which uses plate, as the widget is initialized on page load.
I am still not seeing how just making plate global will update the layouts in the print widget with extent changes.
FC_Basson
That's because the "plate" template has not been redefined in the list of templates for the "printer".  So after each extent change, you also need to redefine the printer templates.  You can define "printer" also as a global variable first.
Try this:
  printer.templates = [plate];
Quynh_NhuMai
New Contributor III
So I believe this is taking me closer to where I need. With the code below, though, I'm having issues debugging the following errors that occurs on map extent change :
-exception in animation handler for: onEnd
-TypeError: Cannot read property 'call' of undefined(...)
I connected the signal to update extents with map extent change within printInfoHandler, as I was having issues with parameters being defined within the latter. I don't know if this is the correct way to do so.
require([
 "esri/dijit/Print",
 "esri/request",
 "esri/config",
 "dojo/_base/array",
 "dojo/dom",
], function(
 FeatureLayer,
 arrayUtils, dom
var center = "";
var latLong = "";
var printer;
var plate;
"url": printUrl,
"content": {
"f": "json"
console.log(latLong);
return;
centerXY: center
return plate;
url: printUrl
printer.startup();
window.myMap.on('extent-change', showExtent());
