ArcGIS Service Publishing Failure
1641
11-22-2016 10:28 AM
DaveTenney
Occasional Contributor III
All,
   please see the attached image for the failure message im getting...
i check the geoprocessing results and there really isnt anything helpful in there. i do however have many error reports from the server stating "Instance of the service 'System/PublishingTools.GPServer' crashed.". I have tried restarting the ArcGIS Service itself, i have also tried restarting the PublishingTools.GPServer in question, with no luck!
Im using Desktop 10.4.1, Server 10.4.1, webadaptor for 10.4.1
any and all help would be appreciated.
Dave
RebeccaStrauch__GISP
Have you already installed make the patch ArcGIS for Server Publishing Patch ?
EDIT:
More things to check:
Error: Packaging succeeded, but publishing failed. ERROR: unable to connect to publishing tools serv...
Error: “Packaging succeeded, but publishing failed”,
I did a browser search for
arcgis server "packaging suceeded but publishing failed"
and got quite a few hits.
EDIT:
DaveTenney
patch is now in place....
   still had same failure
dave
DaveTenney
Update...
   the patch did fix issue, i switched to a different service without imagery and it published.
  checked error logs for publishing tools and its an imagery issue.
thanks Rebecca for your help!
dave
Don't forget to mark this as being answered.
re: the imagery issue, you may want to look at the other links I have above, especially the first one (tech support) which has a list of things to check.
