eSearch Expression Question
857
5
11-22-2016 10:33 PM
RodWoodfordOld
Occasional Contributor III
Hi Robert,
Would it be possible in your next release to include the following expression values
Is Equal To AND Before (Basically less than or equal to <=)
Is Equal To AND After (Basically greater than or equal to >=)
cheers
Rod
RobertScheitlin__GISP
Rod,
   They are already there for numeric fields ("is at most" and "is at least").  Are you needing those for another field type?...
RodWoodfordOld
Yep, date fields in particular.
OK,
   I will look into that.
Rod,
   The 2.2 version that has this is now available.
RodWoodfordOld
cheers Robert,
Your a good man.
Rod
