AnsweredAssumed Answered
Issue loading Search widget intermittently
Question asked by ingenue3911 on Nov 18, 2016
Latest reply on Nov 22, 2016 by ingenue3911
I am attempting to implement a few widgets in my app: search, identify, print, and third-party TOC widget. Each widget works individually, but when bringing it all together, the search widget does not work intermittently (sometimes it works, sometimes it doesn't). The request for the feature returns a result, but the map does not zoom to the feature.
I realized that when the Search doesn't work, the Search.js file does not load at all.
A breakpoint on line 35 of Search.js  is only reached when the widget works..this is not surprising. However, I cannot see what is keeping us from getting there.
var sources = search.get("sources");
UPDATE: This is particularly confusing, as setting enableInfoWindow and showInfoWindowOnSelect to true succeeds in finding the feature and opening the infoWindow for the search. Clicking on the default zoom link succeeds in zooming to the window. However, my app doesn't enable infoWindows for the search, as certain Identify elements are signaled by the opening of infoWindows.
var search = new Search({
enableButtonMode: true, //this enables the search widget to display as a single button
enableLabel: false,
enableInfoWindow: true,
showInfoWindowOnSelect: true,
map: map
}, "search");
The source code is in a public github repository.
When everything works:
When Search does not work--but map loads, print works, and identify works:
The code is also below, if you are willing to take a look:
index.html:
<!DOCTYPE html>
<html dir="ltr">
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>A title</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.17/esri/css/esri.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.18/dojox/layout/resources/ExpandoPane.css">
<link rel="stylesheet" href="css/widget_styles.css">
<script>
var dojoConfig = {
//parseOnLoad: true,
packages: [
//location: location.pathname.replace(/\/[^/]+$/, "") + '../../agsjs'
"location": '/SPE_SIG/agsjs' // for xdomain load
</script>
<script src="http://js.arcgis.com/3.17/"></script>
<script type="text/javascript">
dojo.require("dojox.layout.ExpandoPane");
</script>
<script src="js/Map.js"></script>
<script src="js/Legend.js"></script>
<script src="js/Search.js"></script>
<script src="js/Print.js"></script>
<script src="js/Identify.js"></script>
</head>
<body class="claro">
<div id="content"
data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline', gutters:true"
style="width: 100%; height: 100%; margin: 0;">
<div id="rightPane"
data-dojo-type="dojox/layout/ExpandoPane"
data-dojo-props="region:'right',title:'Outils',startExpanded:false">
<div data-dojo-type="dijit/layout/AccordionContainer">
<div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
data-dojo-props="title:'Légende', selected:true">
<div id="legendDiv"></div>
</div>
data-dojo-props="title:'Impressions'">
<div id="print_button"></div>
</div>
</div>
</div>
<div id="map"
data-dojo-props="region:'center'"
style="overflow: hidden;width: 100%; height: 100%; margin: 0;">
</div>
<div id="tabs" dojoType="dijit/layout/TabContainer" style="width:385px; height:150px;">
<div id="eCompteTab" dojoType="dijit/layout/ContentPane" title="E_COMPTE"></div>
<div id="eTroncoTab" dojoType="dijit/layout/ContentPane" title="E_TRONCO"></div>
</div>
<div id="search"></div>
</div>
</body>
</html>
css:
html, body {
height: 97%;
width: 98%;
margin: 1%;
#search {
display: block;
position: absolute;
z-index: 2;
top: 20px;
left: 74px;
#rightPane {
width: 20%;
#map {
width: 75%;
#legendPane {
border: solid #97DCF2 1px;
h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; }
.shadow {
-moz-box-shadow: 0 0 5px #888;
-webkit-box-shadow: 0 0 5px #888;
#feedback {
background: #fff;
color: #000;
position: absolute;
font-family: arial;
height: auto;
right: 20px;
margin: 5px;
padding: 10px;
top: 20px;
width: 300px;
z-index: 40;
#feedback a {
border-bottom: 1px solid #888;
color: #444;
text-decoration: none;
#feedback a:hover, #feedback a:active, #feedback a:visited {
border: none;
color: #444;
#note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; }
#info { padding: 10px 0 0 0; }
Identify.js:
var eCompteResults
var eTroncoResults
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleMarkerSymbol",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"dojo/on",
"dojo/parser",
"esri/Color",
"dijit/registry",
"dijit/form/Button",
"dijit/layout/ContentPane",
"dijit/layout/TabContainer",
"dojo/domReady!"
function (
Map, ArcGISDynamicMapServiceLayer, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol, SimpleMarkerSymbol,
IdentifyTask, IdentifyParameters, on, parser, Color, registry
parser.parse();
var identifyTask, identifyParams;
// map = new Map("mapDiv", {
// basemap: "streets",
// center: [-83.275, 42.573],
// zoom: 18
//map.on("layers-add-result", initFunctionality);
initFunctionality();
// var landBaseLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer", {
// opacity: 0.2
map.infoWindow.on("show", function () {
registry.byId("tabs").resize();
//map.addLayer(landBaseLayer);
function initFunctionality () {
map.on("click", doIdentify);
identifyTask = new IdentifyTask("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer");
identifyParams = new IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
//identifyParams.layerIds = [1, 15];
identifyParams.layerIds = [0, 2];
identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
map.infoWindow.resize(415, 200);
map.infoWindow.setContent(registry.byId("tabs").domNode);
map.infoWindow.setTitle("Identify Results");
// symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
// new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
// new Color([255, 0, 0]), 2),
// new Color([255, 255, 0, 0.25]));
function doIdentify (event) {
map.graphics.clear();
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams, function (idResults) {
addToMap(idResults, event);
function addToMap (idResults, event) {
eCompteResults = { displayFieldName: null, features: [] };
eTroncoResults = { displayFieldName: null, features: [] };
for (var i = 0, il = idResults.length; i < il; i++) {
var idResult = idResults[i];
if (idResult.layerId === 1) {
symbol = new SimpleMarkerSymbol(SimpleFillSymbol.STYLE_SQUARE,
if (!eCompteResults.displayFieldName) { eCompteResults.displayFieldName = idResult.displayFieldName; }
eCompteResults.features.push(idResult.feature);
else if (idResult.layerId === 15) {
symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 2);
if (!eTroncoResults.displayFieldName) { eTroncoResults.displayFieldName = idResult.displayFieldName; }
eTroncoResults.features.push(idResult.feature);
registry.byId("eCompteTab").set("content", eCompteResultTabContent(eCompteResults));
registry.byId("eTroncoTab").set("content", eTroncoResultTabContent(eTroncoResults));
map.infoWindow.show(event.screenPoint,
map.getInfoWindowAnchor(event.screenPoint));
function eCompteResultTabContent (results) {
var template = "";
var features = results.features;
template += "<i>Nombre d'entités trouvées: " + features.length + "</i>";
template += "<table border='1'>";
template += "<tr><th>NUMERO</th><th>DIAMETRE</th><th>DATE DE POSE</th><th>UD</th></tr>";
var numeroCPTPPT;
var diametreCPTPPT;
for (var i = 0, il = features.length; i < il; i++) {
numeroECOMPTEPPT = features[i].attributes['NUMERO'];
diametreECOMPTEPPT = features[i].attributes['DIAMETRE'];
dateposeECOMPTEPPT = features[i].attributes['DATEPOSE'];
udECOMPTEPPT = features[i].attributes['UD'];
template += "<tr>";
template += "<td>" + numeroECOMPTEPPT + " <a href='#' onclick='showFeature(eCompteResults.features[" + i + "]); return false;'>(afficher)</a></td>";
template += "<td>" + diametreECOMPTEPPT + "</td>";
template += "<td>" + dateposeECOMPTEPPT + "</td>";
template += "<td>" + udECOMPTEPPT + "</td>";
template += "</tr>";
template += "</table>";
return template;
function eTroncoResultTabContent (results) {
var template = "";
template = "<i>Nombre d'entités trouvées: " + features.length + "</i>";
template += "<tr><th>DIAMETRE</th><th>MATERIAU</th><th>DATE DE POSE</th><th>LONGUEUR</th><th>PROFONDEUR</th><th>SECTO</th><th>UD</th></tr>";
var diametreETRONCOPPT;
var materiauETRONCOPPT;
var dateposeETRONCOPPT;
var longueurETRONCOPPT;
var profondETRONCOPPT;
var sectoETRONCOPPT;
var udETRONCOPPT;
diametreETRONCOPPT = features[i].attributes['DIAMETRE'];
materiauETRONCOPPT = features[i].attributes['MATERIAU'];
dateposeETRONCOPPT = features[i].attributes['DATEPOSE'];
longueurETRONCOPPT = features[i].attributes['LONGCALC'];
profondETRONCOPPT = features[i].attributes['PROFOND'];
sectoETRONCOPPT = features[i].attributes['SECTO'];
udETRONCOPPT = features[i].attributes['UD'];
template += "<tr>";
template += "<td>" + diametreETRONCOPPT + " <a href='#' onclick='showFeature(eTroncoResults.features[" + i + "]); return false;'>(afficher)</a></td>";
template += "<td>" + materiauETRONCOPPT + "</td>";
template += "<td>" + dateposeETRONCOPPT + "</td>";
template += "<td>" + longueurETRONCOPPT + "</td>";
template += "<td>" + profondETRONCOPPT + "</td>";
template += "<td>" + sectoETRONCOPPT + "</td>";
template += "<td>" + udETRONCOPPT + "</td>";
return template;
function showFeature (feature) {
feature.setSymbol(symbol);
map.graphics.add(feature);
Legend.js:
var toc, layerInfo;
require([
"esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/_base/array", "dojo/parser", "agsjs/dijit/TOC",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dijit/layout/AccordionContainer", "dojo/domReady!"
], function (
arrayUtils, parser, TOC
parser.parse();
map.on("layers-add-result", function (evt) {
toc = new TOC({
map: map,
layerInfos: [
layer: baseMapLayerWorld,
title: "FDP Esri",
collapsed: true
//layerList: layerInfo
}, 'legendDiv');
toc.startup();
Map.js:
var map;
var baseMapLayerWorld;
require([
"esri/map",
"esri/dijit/Search",
"esri/InfoTemplate",
"dojo/domReady!"
], function (Map, Search, DynamicMapServiceLayer, FeatureLayer, InfoTemplate) {
baseMapLayerWorld = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer");
map = new Map("map", {
center: [-150, -17], // lon, lat
zoom: 8
map.addLayers([baseMapLayerWorld]);
Print.js:
require([
"esri/map",
"esri/dijit/Print",
"esri/tasks/PrintTemplate",
"esri/request",
"esri/config",
"dojo/_base/array",
"dojo/dom",
"dojo/parser",
"dojo/domReady!"
], function(
Map, FeatureLayer,
Print, PrintTemplate,
esriRequest, esriConfig,
arrayUtils, dom, parser
parser.parse();
var printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";
esriConfig.defaults.io.proxyUrl = "http://csslsystem-072/dotnet1/proxy.ashx";
// get print templates from the export web map task
var printInfo = esriRequest({
"url": printUrl,
"content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
function handlePrintInfo(resp) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
return param.name === "Layout_Template";
if ( layoutTemplate.length === 0 ) {
console.log("print service parameters name for templates must be \"Layout_Template\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
if ( mapOnlyIndex > -1 ) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = arrayUtils.map(templateNames, function(ch) {
var plate = new PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Made by: Esri's JS API Team",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "Pool Permits",
"scalebarUnit": "Miles"
return plate;
// create the print dijit
printer = new Print({
"map": map,
"templates": templates,
url:printUrl
}, dom.byId("print_button"));
printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
Search.js:
require([
"esri/map", "esri/dijit/Search", "esri/layers/ArcGISDynamicMapServiceLayer","esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!"
enableLabel: false,
enableInfoWindow: false,
showInfoWindowOnSelect: false,
map: map
}, "search");
//Push the sources used to search, by default the ArcGIS Online World geocoder is included. In addition there is a feature layer of US congressional districts. The districts search is set up to find the "DISTRICTID". Also, a feature layer of senator information is set up to find based on the senator name.
sources.push({
featureLayer: new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/CongressionalDistricts/FeatureServer/0"),
searchFields: ["DISTRICTID"],
displayField: "DISTRICTID",
exactMatch: false,
outFields: ["DISTRICTID", "NAME", "PARTY"],
name: "Congressional Districts",
placeholder: "3708",
maxResults: 6,
maxSuggestions: 6,
//Create an InfoTemplate and include three fields
infoTemplate: new InfoTemplate("Congressional District", "District ID: ${DISTRICTID}</br>Name: ${NAME}</br>Party Affiliation: ${PARTY}"),
enableSuggestions: true,
minCharacters: 0
sources.push({
featureLayer: new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/US_Senators/FeatureServer/0"),
searchFields: ["Name"],
displayField: "Name",
exactMatch: false,
outFields: ["*"],
placeholder: "Senator name",
maxResults: 6,
maxSuggestions: 6,
infoTemplate: new InfoTemplate("Senator information", "Name: ${Name}</br>State: ${State}</br>Party Affiliation: ${Party}</br>Phone No: ${Phone_Number}<br><a href=${Web_Page} target=_blank ;'>Website</a>"),
minCharacters: 0
//Set the sources above to the search widget
search.set("sources", sources);
search.startup();
Outcomes
