Batch Attribute Editor: Almost!
761
11-15-2016 06:10 AM
JamesCrandall
MVP Frequent Contributor
Has anyone had success modifying the Batch Attribute Editor Widget to update GDB tables that participate in a relationship class (1-to-many)?
The Edit Widget does this flawlessly.
Tags (1)
JamesCrandall
In a feeble attempt to implement the desired behavior of updating/inserting into related tables, I took a look a the regular "Edit Widget" (since this does exactly that).
I added the "RelatedRecordsEditor.js" from the Edit Widget and then tried to implement the corresponding code from its "Widget.js" directly into a copied version of the Batch Attribute Edit widget.  When launching the widget I get the error: "Create Widget error: widgets/BatchAttributeEditor2/Widget" and it fails to load.
Again, I simply copied the original, renamed the folder and added the RelatedRecordsEditor.js file:
I did update the manifest.json file's "name" attribute to:
"name": "BatchAttributeEditor2"
Finally, I attempted to implement the corresponding JavaScript out of the Edit widget's Widget.js file and into the BatchAttributeEditor2's Widget.js file:
Adding to the onOpen():
//prepare tableInfosParam data for relatedRecordsEditor
this._getTableInfosParam().then(lang.hitch(this, function(tableInfosParam) {
this.tableInfosParam = tableInfosParam;
this.tableInfosParamClone = this._cloneLayerOrTableInfosParam(this.tableInfosParam);
this._tableInfoParamDef.resolve();
Adding to the define():
'./RelatedRecordsEditor'
And the following methods towards the end of the Widget.js file:
* Methods for prepare edit related records
_createRelatedRecordsEditor: function(feature) {
if(!feature) {
return;
// prepare loading shelter
var loadingDomNode = html.create('div', {style:"position: relative"});
html.place(loadingDomNode, this.editor.attributeInspector.domNode, "after");
var loading = new LoadingShelter({
}).placeAt(loadingDomNode);
// get tableInfosParam
this._tableInfoParamDef.then(lang.hitch(this, function() {
try {
if(this._relatedRecordsEditor) {
this._relatedRecordsEditor.destroy();
this._relatedRecordsEditor = null;
// create relatedRecordsEditor
this._relatedRecordsEditor = new RelatedRecordsEditor({
originalFeature: feature,
editorATI: this.editor.attributeInspector,
tableInfosParam: this.layerInfosParamClone.concat(this.tableInfosParamClone),
nls: lang.mixin(lang.clone(this.nls), window.jimuNls.common)
loading.destroy();
} catch(err) {
console.warn(err.message);
loading.destroy();
this._enableToAnswerEventForEditorATI();
_disableToAnswerEventForEditorATI: function() {
// disable to answer onSelctionChange for editor ATI.
if(!this._mapInfoStorage.editorATIonLayerSelectionChange) {
this._mapInfoStorage.editorATIonLayerSelectionChange =
this.editor.attributeInspector.onLayerSelectionChange;
this.editor.attributeInspector.onLayerSelectionChange = lang.hitch(this, function(){});
_enableToAnswerEventForEditorATI: function() {
// enable to answer onSelctionChange for editor ATI.
if(this._mapInfoStorage.editorATIonLayerSelectionChange) {
lang.hitch(this.editor.attributeInspector, this._mapInfoStorage.editorATIonLayerSelectionChange);
this._mapInfoStorage.editorATIonLayerSelectionChange = null;
_getTableInfosParam: function() {
var tableInfos;
var defs = [];
var resultTableInfosParam = [];
if(!this._configEditor.tableInfos) {
// configured in setting page and no layers checked.
tableInfos = [];
} else if(this._configEditor.tableInfos.length > 0) {
// configured and has been checked.
tableInfos = this._converConfiguredLayerInfos(this._configEditor.tableInfos);
} else {
// has not been configured.
tableInfos = this._getDefaultTableInfos();
array.forEach(tableInfos, function(tableInfo) {
var jimuTableInfo = this._jimuLayerInfos.getTableInfoById(tableInfo.featureLayer.id);
if(jimuTableInfo) {
tableInfo.jimuTableInfo = jimuTableInfo;
defs.push(jimuTableInfo.getLayerObject());
}, this);
return all(defs).then(lang.hitch(this, function() {
if(!tableInfo.jimuTableInfo) {
return;
var tableObject = tableInfo.jimuTableInfo.layerObject;
var capabilities = tableInfo.jimuTableInfo.getCapabilitiesOfWebMap();
var isEditableInWebMap;
if(capabilities && capabilities.toLowerCase().indexOf('editing') === -1) {
isEditableInWebMap = false;
} else {
isEditableInWebMap = true;
if(tableObject &&
tableObject.visible &&//??************
tableObject.isEditable &&
tableObject.isEditable() &&
isEditableInWebMap) {//todo ......
tableInfo.featureLayer = tableInfo.jimuTableInfo.layerObject;
delete tableInfo.jimuTableInfo;
resultTableInfosParam.push(tableInfo);
}, this);
return resultTableInfosParam;
* Methods for change UI
_updateDeleteBtnInToolbar: function() {
if(this._canDeleteSelectionFeatures()) {
this._enableDeleBtnInToolbar();
} else {
this._disableDeleteBtnInToolbar();
_disableDeleteBtnInToolbar: function() {
if(this._configEditor.toolbarVisible) {
query("[class~=deleteFeatureIcon]", this.editor.domNode).style("display", "none");
_enableDeleBtnInToolbar: function() {
query("[class~=deleteFeatureIcon]", this.editor.domNode).style("display", "inline-block");
* Response events
_update: function() {
if(this.editor){
this.editor.templatePicker.update(true);
resize: function() {
this._update();
onClose: function() {
if (this.editor) {
this.editor.destroy();
this.editor = null;
// close method will call onDeActive automaticlly
// so do not need to call onDeActive();
this._worksAfterClose();
onNormalize: function(){
setTimeout(lang.hitch(this, this._update), 100);
onMinimize: function(){
onMaximize: function(){
reClickMap: function(clickEvt) {
this._createOverDef.then(lang.hitch(this, function() {
this.map.onClick(clickEvt);
_onGraphicMoveStart: function(evt) {
this._recordsSelectedFeatureInfoWhenMoveStart(evt);
_onGraphicMoveStop: function(evt) {
this._recordsSelectedFeatureInfoWhenMoveStop(evt);
this._autoApplyEditWhenGeometryIsModified(evt);
_onGraphicChangeStop: function(evt) {
_beforeMapClick: function() {
if(!this._configEditor.autoApplyEditWhenGeometryIsMoved) {
this._checkStickyMoveTolerance();
_onEditorPopupShow: function() {
// disable event for editorATI
var currentFeature = this.editor.attributeInspector._currentFeature;
//var currentLayer = currentFeature.getLayer();
this._disableToAnswerEventForEditorATI();
this._createRelatedRecordsEditor(currentFeature);
_onEditorPopupHide: function() {
// enable event for editorATI
_onNextOfEditorATI: function(evt) {
this._createRelatedRecordsEditor(evt.feature);
_onLayerSelectionChange: function() {
this._updateDeleteBtnInToolbar();
