Union only working on second draw extent
826
8
11-10-2016 09:58 AM
by Anonymous User
Not applicable
Hi all,
I am using geometry service's union to dissolve polygons. It works great. However, I cannot figure out why on my first draw-end my featurelayer selection is done but not the union. If I draw a second extent then it works. not too sure what I am missing here. Thanks,
Alex
here is my code:
 <script>
        var map;
        require([
          "esri/InfoTemplate",
          "esri/map",
          "esri/layers/FeatureLayer",
          "esri/symbols/SimpleFillSymbol",
          "esri/symbols/SimpleLineSymbol",
          "esri/tasks/query",
          "esri/toolbars/draw",
          "esri/tasks/GeometryService",
          "esri/dijit/editing/Union",
          "esri/graphic",
          "esri/graphicsUtils",
          "dojo/dom",
          "dojo/on",
          "dojo/parser",
          "dojo/_base/array",
          "esri/Color",
          "dojo/domReady!"
          function (
            InfoTemplate, Map, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol,
            Query, Draw, GeometryService, Union, Graphic, graphicsUtils, dom, on, parser, arrayUtil, Color
              parser.parse();
              var selectionToolbar, featureLayer;
              map = new Map("map", {
                  basemap: "streets",
                  center: [-97.395, 37.537],
                  zoom: 11
              map.on("load", initSelectToolbar);
              var fieldsSelectionSymbol =
                new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
                  new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
                new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
              featureLayer = new FeatureLayer("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/1",
                    mode: FeatureLayer.MODE_SNAPSHOT
              featureLayer.setSelectionSymbol(fieldsSelectionSymbol);
              map.addLayer(featureLayer);
              $("#selectFieldsButton").click(function () {
                  selectionToolbar.activate(Draw.EXTENT);
              function initSelectToolbar(event) {
                  console.log("start edits");
                  selectionToolbar = new Draw(event.map);
                  var selectQuery = new Query();
                  on(selectionToolbar, "DrawEnd", function (geometry) {
                      var geometryService = new GeometryService("http://itas46:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                      selectQuery.geometry = geometry;
                      featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW);
                      var targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
                      console.log(targetGeometry);
                      geometryService.union(targetGeometry, function (geometry) {
                          featureLayer.clearSelection();
                          var symbol = new SimpleFillSymbol("none", new SimpleLineSymbol("solid", new Color([255, 255, 255]), 2), new Color([255, 255, 255, 0.25]));
                          var graphic = new Graphic(geometry, symbol);
                          map.graphics.add(graphic);
    </script>
Tags (1)
RobertScheitlin__GISP
Alex,
  The FeatureLayer.selectFeatures method returns a promise and it apears that you are not waiting for it to return in your code:
it should be something like:
featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, lang.hitch(this, function(){
   //Now do something with the newly selected features.
Alex,
by Anonymous User
Not applicable
Just tried but the call back does not trigger my geometry service the first time around.
                      featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, lang.hitch(this, function (targetGeometry) {
Alex,
  Does the console.log show more than one geometry the first time through?
by Anonymous User
Not applicable
Yes. It returns the number of polygons selected that are in my "targetGeometry" array as expected.
by Anonymous User
Not applicable
To add to this it seems like
This part is executed correctly, I get my selected fatures and array:
This part does not trigger until the second draw (i dont get any console.log stuff the 1st time i draw and nothing shows up):
 the first time it looks like this:
The second time it looks like this (FYI you can see on the right window that the union has been successful):
Alex,
  try this (added a GeometryService error function):
                              console.log("unioned features");
                          }, function(err){
                              console.log(err);
by Anonymous User
Not applicable
Still No errors (except the XMLHTTPRequest, is that the problem maybe?)
by Anonymous User
Not applicable
That was the issue. Proxy was.
