Slow Swipe Map
751
11-09-2016 07:24 AM
AntonioFiume
New Contributor III
Dear All,
is normal that the maps with one or more Layers are slow?
I tried to replicate this example with ArcGIS for QT Quartz Beta and when i swipe the screen i see the LAG effect :
Feature layer selection—ArcGIS Runtime SDK for Qt (Quartz Beta) | ArcGIS for Developers
This happens only on the iPad, with Desktop works fine.
I tried the same application to different iPad and is the same.
I create a different application only with xCode, without QT, with the same map and layers and the application works perfectly!
Seems that only the QT application is the problem.
This is a common issue for QT or ArcGIS?
Thanks and Regards.
Tony
LucasDanzinger
Esri Frequent Contributor
Tony-
No, that is not normal. Can you please test with the final release that was just released yesterday? If you still see it in Qt, then it sounds like a bug that should be logged with Esri tech support.
- Luke
