Hi, I have an issue in a widget. I found that "onMouseMove" or "onMouseOut" events of a GraphicLayer are not called when a Draw tool is activated with "Draw.EXTENT" or "Draw.RECTANGLE" modes. But, they work with "Draw.POINT" and "Draw.POLYGON" modes.
Sample code;
widget.selectingTool = new esri.toolbars.Draw(widget.map);
dojo.connect(widget.map.graphics, 'onMouseMove', function (evt) {
... bla bla
dojo.connect(widget.map.graphics, 'onMouseOut', function (evt) {
... bla bla
... bla bla
widget.selectingTool.activate(Draw.RECTANGLE);
Is it a bug?
Thanks in advance.
Solved! Go to Solution.
a huarte,
No that is by design. If you really need mouse move events when a Line, Polyline, Freehand Polyline, Rectangle, Triangle, Circle, Ellipse or Freehand Polygon then you have to use the map.graphics.enableMouseEvents(); after you activate one of those draw tools.
a huarte,
Hi Robert, thank you very much! It works fine now.
But It seems only necessary for "Draw.Extent/Rectangle" mode.
Anyway, I always will activate it.
Alvaro
Alvaro,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
