Dutch translation eSearch
471
11-07-2016 05:44 AM
PieterjanWintjes
New Contributor III
Tried to translate (hopeful to satisfaction of other dutch users) everything within the eSearch widget. Here is the Dutch version.
Pieterjan
Tags (1)
RobertScheitlin__GISP
Pieterjan,
  Thanks for your valuable contribution. Would you be able to do the same for the settings/nls in the widget?
PieterjanWintjes
New Contributor III
Robert,
At first I thought: off course I will, but then I saw the amount of texts that needed translation...
Any way this is only meant for the colleagues that need to do the configuration and they all understand the English version, may be even better than the Dutch, so if it's all the same with you I'd rather not spend time here.
Sorry
Pieterjan
Pieterjan,
   OK thanks for the work you did.
