i want to copy a .tpk which is larger than 4gb file on a microsd card which has a fat32 file format. But i am not able to do as the fat32 file format does not supports files larger than 4gb. And i cant format the microsdcard to exfat or ntfs as my android
1096
11-03-2016 01:53 AM
PrateekKumar
I want to copy a .tpk which is larger than 4gb file on a microsd card which has a fat32 file format. But i am not able to do as the fat32 file format does not supports files larger than 4gb. And i cant format the microsdcard to exfat or ntfs as my android device wont support that. Any solutions?
Tags (4)
DanPatterson_Retired
Is there a  reason you are stuck with particular card and storage format?
To reduce file size, it is useful to remove extraneous graphics, reduce the geometry clipping to a particular area of interest, remove any unnecessary fields from tables... remove redundant files from geodatabases and just a general house cleaning of the materials you wish to use.
PrateekKumar
Yes, because I am using a Honeywell CT50 Android device. and it supports only FAT32 format.
then the rest of my advice applies
