AnsweredAssumed Answered
How do you select/move nodes when editing topology?
Question asked by maribethprice on Nov 2, 2016
Latest reply on Nov 16, 2016 by jcadkin-esristaff
I am trying to edit road centerlines using a map topology. In ArcMap you created a map topology, used the topology edit tool to select a node, and when you moved the node, the attached lines came with it and stayed attached.
In Pro, the map topology is on by default and the Modify Features tools have an Edges pane. I can select and edit edges but I cannot seem to select nodes. I've tried both Move and Edit Vertices tools. The Help claims that you can edit both edges and nodes, but they neglect to tell you how to actually select the nodes. If I edit the vertices of the edge, the other lines become unconnected after the end vertex is moved.
In Edit Vertices, if I hover over the intersection I get a little purple circle like it's going to let me select the node, but it never does. In Move, I can select the node (I think), but then I am unable to click and drag it anywhere (see attached video). It just sits there.
Outcomes
