We am operating on ArcMap 10.2.2 and recently downloaded and installed FMV 1.2.1. At the outset, we didn't realize that this version did not come with the Video Multiplexer (a necessary feature for my eventual workflow). Are we able to run the newer versions of FMV (containing the multiplexer) without updating my ArcGIS version OR am are we forced to update our ArcGIS in order to access this feature?
Thanks for your help!
Cheers,
Peter and Jeff
Peter and Jeff,
The minimum version of ArcGIS that supports the video multiplexer is ArcMap 10.3 It is also supported on later versions of ArcMap 10.3.x, 10.4.x and 10.5 slated for mid-December 2016. If you update your ArcGIS before mid-December 2016, you will need to install the FMV Add-In 1.3.1. The new version of the FMV Add-In will be available late December, and will be FMV Add-In 1.3.2.
Regards,
Jeff
