How to import a GeoTIFF and export it as a Shapefile
3020
5
10-31-2016 10:10 PM
antonyCastiglione
I am a completely new user, never used ArcGIS Pro before. I am trying to import a GeoTIFF image file and then end up with a Shapefile i can use in another software. Any help with this is much appreciated.
DanPatterson_Retired
is the tiff fairly simple?  if it is an image like an airphoto, then skip it.  but conversion tools are in arctoolbox some tools require an advanced license however
antonyCastiglione
well i have been playing around with a couple of images, one a satellite image and the other a stitched image from our drone.
How do i even use the conversion tools, nothing seems to work form me.
JayantaPoddar
MVP Esteemed Contributor
You cannot create a vector directly from a satellite image using the conversion tools because the pixel values are too random and areas are too small for grouping.
You need to do Image Classification first. Once done, you could Reclassify to create the LULC classes.
Then you can convert the raster to vector Raster to Polygon—Conversion toolbox | ArcGIS for Desktop
Think Location
antonyCastiglione
The image classification button is greyed out for the satellite image.
Either you don't have the Spatial Analyst extension or you didn't enable it since it requires SA
an example classifier
Maximum Likelihood Classification—Help | ArcGIS for Desktop
