Reg ZoomTo in AWAB Attribute Table widget
916
10-31-2016 09:48 PM
chandupatel
Hi ,
I find some issues with ZoomTo function in AWAB Attribute Table widget. For some layers when I select the record in table view and click on "Zoom To" it zoom in to the selected feature level and works fine as intended. But for few feature when did the same operation it is keep on Zooming out. How do I fix this problem , appreciate your advice,
thanks
Chandu
RobertScheitlin__GISP
Chandu,
   When the zoom to fails to work look for errors in your browsers web console.
chandupatel
Hi Robert,
Thanks, actually it didn't fail or gives error  but instead of "Zoom In" it works as "Zoom Out" and keep on Zooming out when clicked again & again. But for other layers it works fine as "Zoom In" as intended to  no issues.
rgds
Chandu
deleted-user-CQZbjNeBXm49
Occasional Contributor III
Hi Chandu,
What Browser are you using and also what version of WAB?
Baba
Chandu,
   What is the geometry type for the layer(s) that are not acting correctly. And did you check the browser console anyway?
