Hello everyone, we are developing an application based on Web AppBuilder which is running on a tomcat server. But since the network where the application running is not connected to internet, folders like javascript, dojo etc. can not be downloaded.
Does anyone has a suggestion about this problem?
Hi Tevfik,
Robert Scheitlin, GISP is correct, Portal for ArcGIS 10.3 and later releases includes Web AppBuilder embedded within its home app/website and should work fine in a disconnected environment.
Are you asking about using Web AppBuilder Developer Edition with a Portal for ArcGIS installation in a disconnected environment? In which case, yes - you would have to enable access to some ArcGIS API for JavaScript libraries with Developer Edition.
FYI, we just published a blog post on this topic:
Deploying Web AppBuilder for ArcGIS Developer Edition in a Disconnected Portal for ArcGIS Environment | ArcGIS Blog
Hope this helps,
