AnsweredAssumed Answered
Line-Outage Analysis Using Barriers
Question asked by ismaeelgis on Oct 29, 2016
Latest reply on Nov 3, 2016 by jsandhu-esristaff
I am doing outage analysis on a network using barriers points (Red Points) on the midpoints of lines generated by "Generate points along lines". Make a loop for every outage; each time a barrier is applied on a single line (equal to line outage) and solve the problem to find the minimum facilities I need for the network so that every node (14 points) has connection to at least a facility all time. Combining all results of solving location allocation problem should give me the total minimum facilities to be installed in case of line outage. However, I found that the facilities found from the solution contain some extra ones I can delete them with getting the same access to at least a facility which means it is not minimum solution. Any idea?
Note: this question is similar to one I posted recently and asked how to solve location allocation based on facility outage; here we have line outage.
Figure 1: My model to solve the problem
Figure 2: Result (Black Circle) after running the model
Outcomes
