How do I properly clip the mapView?
1468
10-28-2016 07:19 AM
GalinaTurgenev
Dear all,
One of our product require two mapView; one acting as a main map for the application, while the other mapView acts as a mini-map on the top right corner, like so:
The problem I am encountering is that I cannot properly clip the mini-map to be a circle. During my search for a solution, I have encountered numerous ways, which includes but not limited to:
  • Simple XML manipulation with a background with 4 rounded corners (making a circle). This did not work as it seem the mini-map mapView simply ignored its parent's parameters, making the mini map square again.
  • Manipulation involving a custom circle layout (Extended from ViewGroup) with onDispatch() and onDraw() overwritten to clip the provided canvas instance with a circle path instance. This gave a behaviour that I will specify below.
  • Clipping the custom circle layout using a ViewOutlineProvider and overriding the getOutline() method to set the Outline instance as an oval of equal dimensions (a circle). This gave the same behaviour I mentioned above.
The behaviour I mentioned above is very strange and unexpected. In the event that I have the mini-map on top of the main map, the mini-map will simply ignore whatever clipping that I specified. Like so:
(The grey outline is the intended outline of the clipped path, while the red square represents the boundaries of the mini-map)
At first I thought it was simply because I did not set the clipping correctly. However, as I did more tests, it becomes apparent that the mini-map clipping works with every other generic type of view (e.g. FrameLayout, ImageButton), except for other mapView. This is hard to describe, so I will again use a picture. To see this, I made the main mapView half in height and aligned to the bottom, with the mini-map dipping half-way to the mapView.
As it can been seen above, the mini-map will not clip with the main MapView underneath, but will clip with the regular white RelativeLayout in the background (color can be changed, and the clipping still applies). I have struggled many hours over this. An even stranger clipping behaviour will occur if I move the mini-map dynamically with a button; the clipping will clip/revert dynamically as well, depending on if it is above the main mapView.
I would strong appreciate any help on this, as I could not find anything else similar to the situation I am facing. I have suggested to a senior developer that the mini-map be changed to a square, but this strongly goes against the established design, and I would like to give this one last try. Thank you.
AlexanderNohe1
Occasional Contributor III
Can you share the XML that you used above so we can inspect it further?
GalinaTurgenev
Dear Alexander,
I attach XML file for demonstration of strange behaviour.
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
 xmlns:tools="http://schemas.android.com/tools"
 android:layout_width="match_parent"
 android:layout_height="match_parent"
 tools:context="xx.xxxxx.xxxx.MainActivity">
 <!-- The mini-map. The mini-map right now has strange behaviours -->
 <LinearLayout
 android:orientation="vertical"
 android:id="@+id/mini_map_layout">
 <!-- We reserve space for application specific top bar that uses 10 percent of screen-->
 <!-- Hence we have touch space to make the mini-map use only rest 90 percent -->
 <FrameLayout
 android:id="@+id/mini_map_touch_space"
 android:layout_weight="0.9">
 </FrameLayout>
 <!-- For the rest of the 90 percent of the screen -->
 <FrameLayout
 android:layout_weight="0.1"
 android:id="@+id/mini_map_centering_layout">
 <!-- Custom circle layout for mini map in center of screen. Very simple layout -->
 <xx.xxxxx.xxxx.xxxxxxx.CircleLayout
 android:layout_width="350dp"
 android:layout_height="350dp"
 android:id="@+id/mini_map"
 android:layout_gravity="center_vertical|center_horizontal">
 </xx.xxxxx.xxxx.xxxxxxx.CircleLayout>
 </FrameLayout>
 </LinearLayout>
 <!-- Map. The map will only show the bottom half for purpose of demonstration-->
 <LinearLayout
 android:layout_height="match_parent">
 <!-- Usually the layout weight for the touch space is 0.9-->
 <FrameLayout
 android:id="@+id/main_map_touch_space"
 android:layout_weight="0.5">
 </FrameLayout>
 <!-- Usually the layout weight for the main map is 0.1-->
 <RelativeLayout
 android:id="@+id/main_map"
 android:layout_gravity="fill"
 </RelativeLayout>
 </LinearLayout>
</RelativeLayout>
The frames of id "main_map" and "mini_map" are loaded respectively with their mapViews. The mini map uses custom CircleLayout, which I attach below.
package xx.xxxxx.xxxx.xxxxxxx;
import android.content.Context;
import android.graphics.Canvas;
import android.graphics.Path;
import android.util.AttributeSet;
import android.widget.FrameLayout;
public class CircleLayout extends FrameLayout {
 private Path mClippingPath = new Path();
 public CircleLayout(Context context) {
 super(context);
 public CircleLayout(Context context, AttributeSet attributeSet){
 super(context, attributeSet);
 public CircleLayout(Context context, AttributeSet attributeSet, int defStyle){
 super(context, attributeSet, defStyle);
 @Override
 protected void onSizeChanged(int w, int h, int oldw, int oldh) {
 super.onSizeChanged(w, h, oldw, oldh);
 // Find the clipping path.
 float halfWidth = w / 2f;
 float halfHeight = h / 2f;
 mClippingPath.reset();
 mClippingPath.addCircle(halfWidth, halfHeight, Math.min(halfWidth, halfHeight), Path.Direction.CW);
 mClippingPath.close();
 @Override
 protected void dispatchDraw(Canvas canvas) {
 int save = canvas.save();
 canvas.clipPath(mClippingPath);
 super.dispatchDraw(canvas);
 canvas.restoreToCount(save);
Thank you
AlexanderNohe1
After looking into this a bit this morning, I imagine the issue may lie somewhere with the MapSurfaceView which is part of the mapView.  I think more discussion on how to achieve this would be needed.  Additionally, I think it would be a good idea to submit an enhancement request or idea for a guide on how to make circular inset maps.
