Uncaught TypeError: this._onTransparencyChanged is not a function
1094
5
10-27-2016 09:25 AM
RolandoFlorez
New Contributor III
I have the startup function in my Widget.js
startup : function () {
   this.inherited(arguments);
   this.horizontalSlider = new HorizSlider({
         minimum : 0,
         maximum : 1,
         intermediateChanges : true,
         onChange : function (value) {
            console.log('slider value: ' + value);
            this._onTransparencyChanged(value);
            console.log('opacity changed');
      }, this.sliderNode);
   this.horizontalSlider.startup();
   new HorzRuleLabels({
      container : "bottomDecoration"
   }, this.transparencyRule);
   console.log('startup');
but the onChange function, in the horizontal slider, when I try to change the opacity of layers. The console show me the error above.
This is the function:
_onTransparencyChanged : function (opacity) {
   this._vectorial.setOpacity(1 - opacity);
   this._baseAerea.setOpacity(opacity);
And similarly if I put the code of _onTransparencyChanged function in the onChange function I get an error like : cannot read property 'setOpacity' of undefined. What ever I do , got an error.
Thanks a lot
RobertScheitlin__GISP
Rolando,
   That is because this._onTransparencyChanged is out of scope when you are inside the onChange function handler and you are not using lang.hitch.
         minimum : 0,
         maximum : 1,
         onChange : lang.hitch(this, function (value) {
Rolando,
         minimum : 0,
         maximum : 1,
RolandoFlorez
New Contributor III
That's it Robert. I saw this implementation in LayerList widget, but I didn't understand.
Thanks.
Rolando,
  If you are going to do WAB widget development that I would suggest you spend time leaning about dojo templated widgets and definitely about lang.hitch and this.own
RolandoFlorez
New Contributor III
Hi Robert,
Can you tell me, where is the documentation about "this.own" ?
You can find that on the dojo site about  templated dijits
