AnsweredAssumed Answered
Feature Service ApplyEdits is giving error for Updates through SOAP
Question asked by majetivaraprasad on Oct 21, 2016
Latest reply on Nov 9, 2016 by majetivaraprasad
I am running into an issue while I am trying to execute "ApplyEdits" task for updates through SOAP UI. I am facing below error.
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
   <soap:Body>
      <soap:Fault>
         <faultcode>soap:client</faultcode>
         <faultstring>Error processing server request</faultstring>
         <detail/>
      </soap:Fault>
   </soap:Body>
</soap:Envelope>
When I checked ArcGIS Server logs, got below error..
SEVERE     Oct 21, 2016, 3:34:53 PM     Method failed.HRESULT = 0x80004005 : Unspecified error .
SEVERE     Oct 21, 2016, 3:34:53 PM     An error occurred.
Adds and Deletes as part of ApplyEdits task are working fine. It is just that when I am trying to include Update related tags, I am running into above mentioned error.
Below are the various SOAP message XML I am trying with...
Message 1:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:ns="http://www.esri.com/schemas/ArcGIS/10.4"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:ApplyEdits>
         <TableEdits>
            <!--Zero or more repetitions:-->
            <TableEdit>
               <Adds>
                  <DataObjectArray>
                  </DataObjectArray>
               </Adds>
               <Deletes>
               </Deletes>
               <LayerOrTableID>1</LayerOrTableID>
               <Updates>
                  <DataObjectArray>
                  <DataObject xsi:type="ns:GraphicFeature">
                        <Properties>
                           <PropertyArray>
                                <PropertySetProperty>
                                 <Key>OBJECTID</Key>
                                 <Value>9138</Value>
                              </PropertySetProperty>
                                 <Key>Field1</Key>
                                 <Value>Clow Corporation</Value>
                                 <Key>Field2</Key>
                                 <Value>179841833227</Value>
                           </PropertyArray>
                        </Properties>
                     </DataObject>
                  </DataObjectArray>
               </Updates>
            </TableEdit>
         </TableEdits>
      </ns:ApplyEdits>
   </soapenv:Body>
</soapenv:Envelope>
Message 2:
<?xml version="1.0" encoding="UTF-8"?>
xmlns:tns="http://www.esri.com/schemas/ArcGIS/10.4"
   <soapenv:Header/>
   <soapenv:Body>
      <tns:ApplyEdits>
         <TableEdits>
            <TableEdit>
               <Adds>
                  <DataObjectArray>
                  <DataObject xsi:type="tns:GraphicFeature">
                  <Properties xsi:type="tns:PropertySet">
                    <PropertyArray xsi:type="tns:ArrayOfPropertySetProperty">
                        <PropertySetProperty xsi:type="tns:PropertySetProperty">
                           <Key>Field1</Key>
                           <Value xsi:type="xsd:string">179841833227</Value>
                    </PropertyArray>
                  </Properties>
                  <Geometry xsi:type="tns:PointN">
                    <X>187974.69999999925</X>
                    <Y>334501.1000000015</Y>
                  </Geometry>
                   </DataObject>
                  </DataObjectArray>
               </Adds>
               <Deletes>
                 <int>2259</int>
               </Deletes>
               <LayerOrTableID>0</LayerOrTableID>
               <Updates>
                  <DataObjectArray>
                          <Key>OBJECTD</Key>
                          <Value xsi:type="xsd:int">1801</Value>
                           <Key>Field1</Key>
                    </PropertyArray>
                  </Geometry>
                  </Properties>
                   </DataObject>
                  </DataObjectArray>
               </Updates>
            </TableEdit>
         </TableEdits>
         <RollbackOnFailure>true</RollbackOnFailure>
      </tns:ApplyEdits>
   </soapenv:Body>
</soapenv:Envelope>
I am unable to get the proper XML for Updates as part of ApplyEdits. Could someone please help me in resolving this.
Thanks & Regards,
Vara Prasad.
Outcomes
