AnsweredAssumed Answered
FEATURE CLASS FIELD CALCULATION BASED ON ANOTHER FIELD
Question asked by tonalca6864 on Oct 17, 2016
Latest reply on Oct 18, 2016 by tonalca6864
I'm trying to calculate one field in the attribute table of a feature class based on another field with an if/else clause (please see script).
As a test, I used the values of "10" and "20" as results and it works. Now I need to replace that with two more complex expressions using other fields within the attribute table. That is:
Instead of "10" : 0.0006*B*(Q0.31) *(Area_km20.5) *(Z_MAX/1000)*MAT
and
Instead of "20" : 0.02B(Q)-0.31 *Area_km20.5 *(Z_MAX/1000)
"B"; "Q"; "Area_km2"; "Z_MAX"; "MAT" being those other fields in the attribute table.
I'm not quiet sure how to include those fields as well as the Power function within the codeblock part of the script.
Any help would be greatly appreciate it.
Many thanks
    # Add "BQART_QS" field to Nodes FC
arcpy.AddField_management(nodes, "BQART_QS", "Double")
BQART_QS_expression = "calc(!MAT!)"
codeblock = """def calc(val):
    if val >= 2:
        return 10
    else:
        return 20"""
arcpy.CalculateField_management(nodes, "BQART_QS", BQART_QS_expression, "PYTHON",codeblock)
Outcomes
