AnsweredAssumed Answered
Odd problem with delineations; whether using Polygon, Rectangle construction tool the end product is askew. When I try correcting the delineation by deleting or adding vertices doesn't fix the problem. I'm using 10.3
Question asked by awhitley67 on Oct 14, 2016
Odd problem just started recently when editing. When editing and creating shapefile for impervious surface delineations the end product is askew. I'm just using polygon or rectangle construction tools and then merging but end result gives me odd behavior.  I've attached the result of drawing 2 rectangles and then merging to better illustrate the end result.
I've tried repairing Arcmap and am now looking at adding patches. Curious if anyone else has had this problem. I am using Arcmap 10.3 and the deliineation is part of a geodatabase hosted on Arcgis Server running sql express
Outcomes
