Get the current extents of the map
4642
10-14-2016 01:45 PM
MuktaPuri
I've added a map by setting the center and zoom on the mapView like so:
var view = new MapView({
    container: "viewDiv",
    map: map,
    zoom: 4,
    center: [15, 65]
After the map loads, we need to determine the current bounds of the map so we can query our database for data within those extents.
What is the best way to determine the current map extent after the map has loaded?
Tags (3)
thejuskambi
Occasional Contributor III
view.extent property should give you the current extents of the map.
extentExtent
The extent represents the visible portion of a map within the view as an instance of Extent.
thejuskambi
extentExtent
