Unable to edit a "Extent" Draw Tool
1736
7
10-10-2016 03:04 PM
PriyaRam
New Contributor III
I'm trying to edit an extent graphic using the EditTool and I'm getting the following error.
activeEditToolbars(evt) {
if (this.editingEnabled) {
this.editingEnabled = false;
this.edittoolbar.deactivate();
else {
this.editingEnabled = true;
this.edittoolbar.activate(Edit.EDIT_VERTICES|Edit.MOVE, evt.graphic);
Uncaught Error: [esri.toolbars.Edit::activate] Unable to activate the tool. Check if the tool is valid for the given geometry type.
Tags (1)
RobertScheitlin__GISP
Priya,
  Editing a extents vertices is not allowed because that would change the geometry type to a polygon. You can only scale, move and rotate.
PriyaRam
New Contributor III
Hi Robert - That makes sense. Yet, I'm still having problems with the scale,move operations . Please advise. (Error Message:[esri.toolbars.Edit::activate] Unable to activate the tool. Check if the tool is valid for the given geometry type.)
else {
if(evt.graphic.geometry.type === "extent") {
this.edittoolbar.activate(Edit.MOVE|Edit.SCALE, evt.graphic);
else {
Priya,
   What happens if you only include Edit.MOVE?
PriyaRam
New Contributor III
Robert - It's the same issue, as stated above.
Priya,
   I have to apologize as it seems that the Extent Geometry type is not a supported type for any operation in the edit toolbar. If you want to do anything with an extent you must first convert it to a polygon.
PriyaRam
New Contributor III
Hi Robert - That's good to know.
Please see,if this function looks okay for constructing a polygon.I'm getting an error, Cannot read property 'spatialReference' of undefined.should I update the geometry ? Any samples is much appreciated.
//console.log("evt.graphic",evt.graphic);
let tempPoly = this.convertExtentToPolygon(evt.graphic,new SpatialReference({wkid:102100}));
console.log(tempPoly.geometry);
this.edittoolbar.activate(Edit.MOVE, tempPoly);
convertExtentToPolygon (extent, spatialRef) {
const xmin = extent.xmin;
const xmax = extent.xmax;
const ymin = extent.ymin;
const ymax = extent.ymax;
const topLeft = new MapPoint(xmin, ymax, spatialRef);
const topRight = new MapPoint(xmax, ymax, spatialRef);
const bottomRight = new MapPoint(xmax, ymin, spatialRef);
const bottomLeft = new MapPoint(xmin, ymin, spatialRef);
var rings = new Array(topLeft, topRight, bottomRight, bottomLeft, topLeft);
var newPolygon = new Polygon(spatialRef);
newPolygon.addRing(rings);
return newPolygon;
Priya,
  You should just use the Polygons fromExtent method:
Polygon | API Reference | ArcGIS API for JavaScript 3.18 | fromExtent
