Built form - four towers on a podium
1121
10-09-2016 02:48 PM
CoMAGOL_ADMINISTRATOR
We're writing a write a built form rule that consists of a podium and four towers. Each tower is to have their own configurable setbacks.
We've tried placing a splitArea command with a splitArea command, but this simply creates
splitArea(z) { ~1 : splitArea(x) { '0.5: TowerLots}*
| ~1 : splitArea(x) {'1 : TowerLots}*
split.index 0 is tower 1
split.index 1 is tower 1
split.index 2 is tower 2
split.index 3 is tower 2
Multi-tower podium
Wondering if anyone has any ideas on how best to split the podium into four so we can assign a tower to each of the split indexes?
i.e.
split.index 1 is tower 2
split.index 2 is tower 3
split.index 3 is tower 4
Thanks.
LR
Occasional Contributor III
The split.index is overwritten on a new split. You're splitting once, creating two polygons (index 0 and 1), and then you're splitting those too, creating index 0 and 1 or each. AFAIK you'd have to store the index info somewhere, like this:
attr CumulativeSplitIndex = ""
@StartRule
 Lot -->
 splitArea(z){ '0.5: TowerLots1}*
TowerLots1 -->
 set(CumulativeSplitIndex, "z"+split.index)
 splitArea(x){ '0.5: TowerLots2}*
TowerLots2 -->
 set(CumulativeSplitIndex, CumulativeSplitIndex+"x"+split.index)
 print (CumulativeSplitIndex)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This should give you addressable lots for a conditional rule. Alternatively, you could of course do it all manually, like this:
attr SetBack_1 = 0
attr SetBack_2 = 0
attr SetBack_3 = 0
attr SetBack_4 = 0
@StartRule
 Lot -->
 splitArea(z) {
 '0.5: Split_Z_1 | '0.5: Split_Z_2
Split_Z_1 -->
 splitArea(x) {
 '0.5: Split_X_1_1 | '0.5: Split_X_1_2
Split_Z_2 -->
 splitArea(x) {
 '0.5: Split_X_2_1 | '0.5: Split_X_2_2
Split_X_1_1 -->
 setback(SetBack_1){all: X | remainder: Tower}
# repeat for rest
Tower --> extrude (10)
LR
@StartRule
 Lot -->
TowerLots1 -->
TowerLots2 -->
attr SetBack_1 = 0
attr SetBack_2 = 0
attr SetBack_3 = 0
attr SetBack_4 = 0
@StartRule
 Lot -->
 splitArea(z) {
Split_Z_1 -->
 splitArea(x) {
Split_Z_2 -->
 splitArea(x) {
Split_X_1_1 -->
# repeat for rest
Thanks very much LR that's done the trick!
