KeyboardEvent.keyIdentifier' is deprecated and will be removed
995
10-06-2016 09:38 AM
DanielStoelb
Occasional Contributor III
I'm working on writing an app using the 3.18 version API and there appears to be a notification for Chrome (and a resulting no-show on IE 11) for the portion relating to the dijit text box.  Here is the specific notification I'm getting:
From what I can tell, this is pertaining to the JS file from the API.  Is there something else I should be using for the text entry in the text box.  As a reference, here is the code I'm referring to:
on(dijit.byId("stringTextBox"), 'change', function(value){
var userVal = dijit.byId("stringTextBox").get('value');
KellyHutchins
Esri Frequent Contributor
Should be ok - here's the dojo issue regarding this one. https://bugs.dojotoolkit.org/ticket/18893
You mentioned something about a no-show in IE? Can you provide more details?
KellyHutchins
DanielStoelb
The data from the feature service wasn't showing in IE. I did some digging and found out that my browser was forcing compatibility view based upon group policy (forcing IE 7).  After switching to the more recent versions of IE emulation (8 and above), it appears to be displaying.
Thanks for the reference in the dojotoolkit.  I thought I would pass it along in case someone else had a similar warning.
